Barefoot
By now I wonder if we are even talking about the same thing.
Lou Park wrote:I have an idea, but lets see if I can explain it.
You’re going to have to remove the top/back to do this. At the bottom of the rising top, attach an L bracket to the plywood bottom, then attach seat belt material (because its skinny and very strong) to the L bracket going in between the raised top/back and the stationary back. At the top of the plywood of the stationary back the seat belt material would go over and back down that plywood over a bearing (metal tube with a bolt through it.) and down inside the camper wall, through the floor bent 90deg toward the center of the camper under the frame to a ratcheting boat winch in the center. One from each side to the center winch so when you crank the winch, the seat belt material wraps up and pulls on the belt which pulls the side up. Lou
Lou Park wrote:Draw it up, I can see it in my head, but on paper would be great.
My only concern is when the top is all the way up, the L bracket is
all the way aft, but when in the down position, it looks to be about
12" forward. The L bracket may need to be on a swivel.
Lou
starleen2 wrote: I think that 1 inch wide nylon strap will do just fine and forget about the L bracket – I have a pneumatic air tacker – Just staple the strap to the bottom of each wing. )[/size]
Lou Park wrote:starleen2 wrote: I think that 1 inch wide nylon strap will do just fine and forget about the L bracket – I have a pneumatic air tacker – Just staple the strap to the bottom of each wing. )[/size]
L bracket is up to you, I would be afraid that the tacks would eventually rip out while cranking up. Both at the same time wouldn't be too bad, but if only one ripped it could be disastrous..
Lou
starleen2 wrote:Are you talking about the L bracket over the nylon webbing?
