Ageless wrote:Duane; the concept about vacuum bagging is that you remove most of the air from the surface. That allows normal atmospheric pressure; about 7 lbs per sq.inch. to apply even pressure.
Duane King wrote:
I like the homemade panels that Bruce did with the plastic sheeting and the shop vac. Pretty neat. What kind of glue did you use to laminate everything together, Bruce? Did the shop vac really keep everything flat while the glue dried?
bdosborn wrote:I was worried about the motor on the shop vac burning out from overheating but someone on the list pointed out that the motor is unloaded since its not pulling any air. I ran it for hours without any issues.
eamarquardt wrote:Ageless wrote:Duane; the concept about vacuum bagging is that you remove most of the air from the surface. That allows normal atmospheric pressure; about 7 lbs per sq.inch. to apply even pressure.
Not to quibble but atmospheric pressure is about 14.7 psi. A typical shop vacuum can pull 60" of water column or about 2.2 psi. 2.2 psi over a 4X8 sheet of plywood is over 20,000 pounds or ten tons. As the pressure is between the two sides of the plastic bag the vacuum pressure will not flatten out the sandwhich but gravity should do a reasonable job (or you could put some additional weight to flatten out the sandwich during the bagging process) of keeping the sandwich flat. The pressure generated by the vacuum bag (again about ten tons for a typical 4X8 sheet and shop vacuum) will do a good job of keeping the sandwich together as the glue sets up.
Gus
Cliffmeister2000 wrote:For your application, how about the plastic corregated sheets that I've seen real estate people make signs out of? Strong, light weight, and waterproof.
http://www.coroplast.com/
