In other words learn by others mistakes and all will be well
" Don't make provision for failure"
NathanL wrote:To paraphrase a famous quote in engineering.
It's not perfect when nothing can be added.
It's perfect when nothing can be taken away and it still function.
angib wrote:One of the things the over-engineers need to consider is that many of the critical strength issues for trailers are G loads (or acceleration) - typically when one wheel runs over some object in the road.
Now building strong and heavy feels good but the extra weight just increases the G load on the part - so most or all of the extra strength gets used up just supporting the extra weight.
Strong-but-light is the really good way to go.
Andrew
Forrest747 wrote: When I try to design something or put a setup together I try to look at it from the manufacturing or service point of view.
2bits wrote:To answer the initial question, I think people tend to over engineer the frame, and the walls the most. I think I did well in this area. 3/4" plywood walls, but I am most proud of my frame.
Made out of two 24 foot bars of 2x2 steel. I "engineered" it where the steel mill could do a rough cut right in half (try to keep it simple) so I could get the 4 12 foot pieces home in the back of my truck. I laid out the cuts and got it just like this with the tongue A-frame right back to the axle and had only 4 inches of tube left. I call that Economically engineering!
(Obligatory photo)
Users browsing this forum: Google [Bot] and 9 guests
