by happy_camper » Sun Feb 13, 2011 6:45 pm
"kirkman":
Thanks for the information on the heater; I'd looked through your album but couldn't determine if it was 120 VAC or a 12 VDC version.
I asked about the voltage wondering if "boondocking" without the heater, in the temps you tested in, would have been comfortable enough to do again? There seems to be wide agreement that a 12 VDC heater would drain a "house" battery if run full-tilt, all night, as your 120 VAC heater did. Wondering if even a very well insulated trailer would be comfortable enough, without a heater, while "dry" camping at -10°F.
You (and others) mention that using the roof vent to rid the trailer of the warm, moist air exhaled overnight would decrease the accumulated condensation inside. But on the other hand, wouldn't even a slightly cracked roof vent simply be the quickest way for the rising warm air to exit your trailer, requiring even more heat from some source? A conundrum for sure.
Good luck on your next test - keep us posted.
"Never try to teach a pig to sing; it wastes your time and it annoys the pig." — Robert Heinlein
"Mechanical difficulties with language are the outcome of internal difficulties with thought." — Elizabeth Bowen
"I would challenge you to a battle of wits, but I see you are unarmed!" — William Shakespeare
"It ain't about the numbers, I can count to five just like you'se guys" — Six Finger Chatowski
