Little Guy Owners?
Postby Dogs_rule » Tue Mar 15, 2011 2:50 pm
I ordered mine about two weeks ago. It will be a Five Wide with the power package, rough rider axle and tires (no undercarriage plates), black shades, and Silver in color to be a little more retro. I'm hoping it gets here by the first of the month. I'm going to put a memory foam mattress topper on top of the supplied mattress for that cushy feel. Eventually I would like to put a Yakima rack system on it.
Can't wait!!!
Rick
Dogs_rule
Postby bobditch » Wed Mar 16, 2011 5:54 am
Mike-n-Britney wrote:We added a volt meter to the battery box, installed reverse lights
You have a nice setup. I'm curious about the volt meter and reverse lights you added.. Can you sent me some pics and install info.. I know just enough about electric to get me in trouble .
Thanks,
Bob
Little Guy 5 wide
07 Xterra 4WD
Yakima bike & kayak racks
<img src="http://www.mikenchell.com/forums/album_pic.php?pic_id=76503" border="1" />
bobditch
Images: 9
Postby bobditch » Wed Mar 16, 2011 6:04 am
Dogs_rule wrote:I'm going to put a memory foam mattress topper on top of the supplied mattress for that cushy feel. Eventually I would like to put a Yakima rack system on it.
We're going to try out a memory topper this yearvas well. The supplied mattress is just a tad hard (although it does beat the ground).
Wevhave a Yakima system on the Xterra for kayaks and a Yakima bike rack on the back of the LG; great stuff..
Congrats on your new purchase.
Our first outing this year is in 3 weeks in the Smokeys. Can't wait!
Little Guy 5 wide
07 Xterra 4WD
bobditch
Images: 9
Postby Rvankeur » Wed Mar 16, 2011 7:02 am
We picked up a 2011? 5x10 Silver Shadow in the fall. Haven't had a chance to do much other than make curtains and add a couple of coat hooks by the door.
Ed has considered putting a hitch receiver up on the tongue as a place to store the hitch mounted bike carrier with the bikes attached. We'll need to live with it a while before we can see exactly what needs changing.
Rose and Ed
Rvankeur
Postby Mike-n-Britney » Wed Mar 16, 2011 10:17 am
bobditch wrote:You have a nice setup.
THANKS!
bobditch wrote:I'm curious about the volt meter and reverse lights you added.. Can you sent me some pics and install info...
I tend to get long winded, so please bear with me:
Because of our work schedules, we usually head-out on camping trips Thursday late afternoon. Often enough, this makes it dark by the time we get to the campsite. As much as I love my wife, she doesn't understand backing a trailer, therefore is terrible help trying to back into a slot in the dark. So I added back-up lights to the trailer.
I got a $20 set of fog/driving lights from Walmart, and mounted them inside the ends of the tongue tubes (the ends are open just underneath the side doors). They fit just perfect inside the tube and they angle just perfect to shine on the tires and out to the sides and behind the trailer.
The alternator on my car is just powerful enough to keep the car going, so I didn't want to stress it more with charging the trailer battery. So, I replaced the 7-pin connector on the trailer with a flat 5-pin connector. 5-pin is becoming the new standard for boats, as it has all the normal 4-pin functions, plus a reverse pin to lock-out surge brakes for reversing (and back-up lights). I re-wired my car from flat 4-pin to flat 5-pin (tapping the reverse lights) - which will still plug into a flat 4-pin connector like on my 4x8 utility trailer.
My car has a finicky electrical system anyways, so I didn't want to over-power the cars reverse light circuit... So, I got a waterproof project box, and a relay from Fry's. I mounted the project box onto the battery box and ran all the wires through a grommeted hole between the two. The cars reverse lights close a relay in the project box, to turn on the trailer reverse lights which are powered by the trailer battery. Sounds complicated, but it's really simple - and keeps the cars electrical system isolated from the trailers.
I figured while I was at it (and at Fry's) I got a waterproof volt meter, and a waterproof momentary button switch - I drilled a large hole (actually used the 3-axis at work to do it) in the cover of the project box to mount the volt gauge and a smaller hole for the button. I just tapped into the power leads for the relay, and now anytime I want to check the battery voltage, I just push the button ant the meter shows the voltage. It's debate-able how useful the meter is, but it was easy, fun, and just may keep me from killing the battery sometime.
I'll snap a couple pics of the lights and meter/project box and post them...
RIP: 2006 GTO
2005 Audi allroad 2.7T
2008 Silver Shadow
Mike-n-Britney
