Py0tr wrote:One pointer given to me about reversing trailers was not to over correct. Turn the wheel no more than you would to move the car the same amount, rather than spinning it around wildly.
\the other side wrote:I think I'm going to try to get that hitch extention too! It would be worth a few buck to eliminate this backing problem!
Wimperdink wrote:I'm thinking that easy to use hitch extension will make the problem worse. It extends the hitch instead of the trailer tounge. The distance between the ball and the trailer axle remains the same but the distance between the ball and the TV axle is longer. I'm guessing its going to make it even more touchy to over correction. Someone else jump in here if Im wrong please.
