What about this trailer as a TTT????
Postby Kevin & Sandy » Fri Oct 07, 2011 1:12 pm
How about sleeping with your feet towards the front, that may allow you to use that room a little.
Then put your mattress up a foot off the floor and build a big slide out drawer that has your gear in it? Combine that with the use of a chuckbox maybe.
:thinking:
Kevin & Sandy
Images: 46
Postby jonnyo » Fri Oct 07, 2011 2:25 pm
you guys are awesome with ideas! I m going tonight to check on it and mesure the inside and see what could be done. I think a slide out at the back to extend the sleeping space/kitchen might be the best option.
But nothing like looking at it in person to have a good idea.
What is the lenght that someone 5'9 needs for sleeping comfortably without your feet and toes touching the wall? 6 feet?
jonnyo
Postby chartle » Fri Oct 07, 2011 2:36 pm
jonnyo wrote:you guys are awesome with ideas! I m going tonight to check on it and mesure the inside and see what could be done. I think a slide out at the back to extend the sleeping space/kitchen might be the best option.
You have to allow for the fact that you wouldn't sleep with your head touching the headboard and that you would point your toes when you sleep. A standard mattress is 75" for a twin, 80" for a queen.
chartle
Postby iSpy » Fri Oct 07, 2011 2:38 pm
Hi,
You may be interested in my fibreglass CT which I built some years ago....
http://tnttt.com/viewtopic.php?t=44261
Above is a link to the project.
Good Luck
iSpy
Postby jandmz » Fri Oct 07, 2011 9:47 pm
You might consider putting the bed in the back, and adding doors to the sides of the V-nose for a galley on one side and storage on the other. It would depend upon the length of the body behind the V being long enough for the bed.
jandmz
Postby JuneBug » Sun Oct 09, 2011 11:36 am
A plus factor to the cargo door is that you could easily load your tri bike in there out of sight and out of the elements while on the road -- just set up the mattress to fold in the middle and push to the side to roll the bike right in.
"The large print giveth; the small print taketh away" Tom Waits
JuneBug
