canned o minimum wrote:Anything done by YER hand is much more desirable than store bought ! AND.. you git to enjoy makin it and givin it as a gift as well. Everybody wins !
Absolutely agreed, it also stops you from killing yourself or some unsuspecting person.
Right where do I start??
Had an electician here for 5 hours today at £25/hour to wire the shed up to the mains via a 6mm armoured cable and to fit a consumer unit (Not sure thats the right name for a distribution box)
By the end of the day at 3pm I had 8 plugs linked to the mains and could work any of the machines or lights I have in the shed.
He will be back next Saturday to fit a 4ft strip light and rocker switch at the door, probably another £50.00, then all the wiring and lighting should be done.
Personaly, I would have love to do it all myself, but Nicola put her foot down and said we need a wiring certificate, in case anything ever went wrong.... so I capitulated and did other stuff while Mark sorted the electrics out, the upshot was that I got a bacon sandwich at lunchtime when she fed Mark.... yahoo !
Did I mention that there was a bit of candle holder envy from Nicola's mum after she claimed the first item as a candle holder??
So I decided to make her something nice out of Tulip wood.
Started by measuring out on the wood I had and then cutting out on the bandsaw, after which I used woodglue to laminate the two bits. I will let them dry for 24 hours, which is way more time than needed, and then turn somethig like a candle holder.
Measured and drawn.
Cut out...
After this I cut the grass and kept busy while the shed was being wired.
Once Mark left, I took a bit of what I asume is Sapele Mahogany and started turning some stuff that was on my mind.
I initially tried to make the two right hand knobs with grooves cut in, like the first plate, but it did not work for me, so I re-cut and reshaped them. followed by sanding.
It seems mad, but up to that point took me 2 hours, as mentioned by someone before... wood turning absolutely sucks up time.
Finally after cutting them loose, I had 3 gearknobs.....
HANDMADE and UNIQUE.
I am prepared to sell them on here or elsewhere at what is hopefully sensible money.... at £7.50 each incl postage, unless you want to collect, in which case they are £6.00 each. This is in the UK by the way.
I have marked them 1,2,3 and have not drilled them as various applications will have different shaft sizes.
If interested, please PM me and say which one you want.
I will deal with it straight by time of PM arrival, so if 3 people want the same one, the first PM gets preference.
I want any interested parties to note, these are hand made and not perfect like a factory moulded or mass produced knob. In future I will experiment with adding tops to them as well.
Front/top views.
Bottom, to show the numbers and what you will have to deal with when drilling a hole.
Please note, the Pound coin is just there for illustration.
LAST THING ......
A Captive Ring (I thought it sounded rather rude)
I made this one just to prove to myself and also to try out a custom tool I have made up, to be able to cut around corners.
Hope you like the updates.
Please do leave comments about the knobs and pricing, or send me a PM if you want to be really honest.
Thanks for looking in.
Greetings from England.
Rian.
