Heated Floors
Postby 86bigred » Mon Jan 23, 2012 12:04 am
i have read some where that all you need is a small rv hot water tank,run your lines under the floor and hook up a pump on a thermostat. or run your water lines to a small tractor heater and run the fan and pump off the thermostat.hydronic heating.
here is a link http://rixens.com/system.htm
86bigred
Re: Heated Floors
Postby doug hodder » Mon Jan 23, 2012 12:42 am
Vedette wrote:Okay
After seeing a Teardrop in the snow at Yellowstone in the summer.
Just me...but I think you are over thinking it, just how often are you planning on camping in those conditions....many of us have camped well into the 20's with no "onboard" heat and have been fine and it wasn't a summer thing...daily temps were only in the 40's. It was spring in the high desert of Nevada. It's camping!
Many of us just put a lantern in the tear prior to going to bed...have some decent bedding to account for the temps. The interior of mine was in the upper 40's in the morning and it snowed during the night. I was comfortable and I didn't have my dog with me to help heat it up. Kinda depends on your camping mate if you have one.
If you want heat and not deal with any of the elements....no matter what you do, it's gonna cost ya, dollars and time or get a larger RV. Whether it be a furnace, pet cool, blanket that may suck down a battery or whatever.... and if you are camping in a tear...and it's warm...are you gonna sit inside all day long?...get out and build a fire..it's camping! Doug
Postby smatthew » Mon Jan 23, 2012 10:50 am
I have often considered purchasing a Webasto ThermoTop - it's a diesel heater intended for pre-heating engines, so it produces hot coolant. Plumb that below the floor in pex for some nice radiant heat ;-} Plus add a heat exchanger and you've got hot water in the sink!
smatthew
Postby Vedette » Fri Jan 27, 2012 11:22 am
Thanks Guys
From your comments, I am now concidering a very small (cheap) 12v heater or an electric blanket for on top of us.
Thanks for your imput.
Good Roads
Brian
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Postby Senior Ninja » Fri Jan 27, 2012 2:58 pm
I'm with Doug on this one. "It's camping." If you want all the comforts of home... I insulated, especially the floor. We've never been cold even a eight thousand feet at Big Trees State Park in CA. Don't want to let the heat out to go pee? I thought that's why they made sports drink bottles. Just a squirt of two of liquid hand soap and a little mouth wash to kill the odor. Empty in the morning in the rest room or throw it out the window at that big RV tailgating you (Just Kiddin") I'd just add two things. First invest in a hot water bottle. Second, wear a knit hat to bed. Lots of heat escapes through your head.
Building the TD was the best thing I ever made.
Senior Ninja
Postby DMcCam » Fri Jan 27, 2012 7:26 pm
Hi Brian, You might want to do a couple of searches for heating threads. It's been covered pretty well. We ended up adding a 12 volt socket at the foot of the bed for a mattress heating pad like the truckers use. NevadaTear turned us on to it. If you use it to warm up the bed 20 minutes or so before you climb in, you can turn it off and sleep well in freezing weather.
Dave
DMcCam
Postby Vedette » Sun Jan 29, 2012 9:27 pm
Thanks Dave
We will have a 12v socket in the sleeping area, so this might be just what we need.
I am trying to keep things simple, but I don't want to miss something that iis easy to install during the build.
All ideas and comments are taken into consideration!
Thanks again.
Good Roads
Brian & Sandi
Good Roads
Brian & Sandi
Vedette
Images: 443
Postby Martiangod » Sun Jan 29, 2012 9:54 pm
I renoed a house in winter a few years ago, slept in the basement without heat...Winter and little electric, froze my butt off.
Got a brainstorm one day had some 2" pink styrofoam, put it under my air mattress, just about cooked that night.
Even if your floor is insulated I would get some Pink or Blue styrofoam and put under bed.
Just sit on a piece of styrofoam and you will know what i'm talking about
We late camp with our previouse trailer into the first few snows, even with furnace running feet were cold at table, put a piece of styro under our feet and it was wonderfull.
I even have styro under my feet at my computer desk in winter, we keep heat down..
Chris
Deep in the Heart of Nowhere
Martiangod
Images: 432
Postby DMcCam » Mon Jan 30, 2012 10:40 am
Martian has the right idea for sure. In essence we're doing the same thing with our 5" foam mattress (4" dense foam with 1" additional memory foam on top). All that insulation with a mattress warmer is what our good friends have too. Here's a link to their build thread.
http://www.tnttt.com/viewtopic.php?t=41295
I like the idea of less is more.
David
DMcCam
