I think it is cute but overkill. Standing up in a Teardrop is something I like to do myself. But I don’t think this is the way to do it.
I do not believe this is photoshop. There is no tell-tell sign of photoshop on the pixel level. All the objects in behind the plastic
still look right. The reflection of the palm trees on the front and the reflections on the palm trees in the fender would be to hard
to get right and I don’t think someone would place them on the fender. A pointed out there are cabinets in the back, but I’m sure
I can mount cabinets in a tear without touching the sides.
I Thinking it is not a true “Park and Raise the top” pop up teardrop. Lets imagine the cabinets in the back
have room on both side so support section ( the section under the windows frames ) to slide up and down.
The height of the top area ( with windows ) and the support area would be too tall to fit in a 4 foot height teardrop.
Again I thinking the guy parked it there. Raised the roof section, unfolded the front and back window. Places
in two side supports. Front of the support bolts to side wall or goes to the floor. The back support bolts to wall,
rest on the cabinets, or goes to the floor. Later the side where added. I’m not sure the sides of the pop up part
traveled in the TD itself. If they were just lowered they would block the door and windows ( if any on the other side).
I think it is still a work in progress. If you look at the front the the pop up section under the set of windows with the
palm trees reflection you see there is no panel installed. what you are seeing is the Left inside of the tear drop or at
least the left inside of the supporting section. Also you can see a hole above the door in the support section exposing
the same inside left wall. See picture I marked the spot and added a few CAD pic of what I’m seeing.
I’m drawing up some planes my self for a pop-up Benroy and will start it own thread this winter in the design section so
stay tune for that boys and girls.
