burlesot wrote:If I plan on camping away from power sources, how do I figure out how 'long' I could run my teardrop (only using LED puck lights in the cabin for one hour average and the fantastic fan on high for 8 hours a night) using a deep cycle marine battery?
Fantastic Fan on HIGH for 8 hours??? Really? That is both loud, and a major current draw. My girlfriend won't let me run mine on low overnight because it's too loud for her (I don't mind) According to their website max current draw is three amps. This is your major concern. The LED lights have a minimal current requirement.
Know also that there is no "absolute" time for this. If you want to run your battery until the fan no longer works ... that's up to you ... but it will SERIOUSLY damage your battery. The less you discharge your battery (before you re-charge it) the less damage is done and the longer it will last ... but the time you get to use it each time is less. I run a digital voltmeter to monitor my battery. 10.5 volts is the mimimun most say that a deep cycle battery should be drawn down to .. but, again, 11 volts, or even 11.5 volts will make the battery last longer. (and a fully charged 12 v battery starts out at about 12.6 volts)
There are many types of "deep cycle marine batteries" ... some better than others. What is the amp hour rating of your battery? Without that information no one can begin to tell you how long it will last under a specific load. Also how old is it, and how has it been maintained?
Also ... since you have a Fantastic fan/vent .. where are you going to mount your solar panel(s)?
