nevadatear wrote:Actually, a foam mattress is not necessarily less comfortable than a spring mattress. Temperpedic ones are all foam. High density foam topped with a thick layer of memory foam. I have another brand of the same type of mattress at home, just less pricy than temperpedic. I have similar in the tear from Walmart, and it is actual more comfortable than my home mattress, just muchless expensive. Foam mattresses don't have to be a " little bit of foam .". Mine is 6"' 4 of high density foam and two of memory foam, it does roll up, which was very handy when there was a leak and I needed to dry out the floor. But it only cost less than $200. Slow it's a mistake to assume only a spring mattress can be truly comfortable in a tear. Some of the most expensive and highest quality mattresses on the market are foam.
