Tongue jack for teardrop?
Re: Tongue jack for teardrop?
Postby dave_dj1 » Fri Sep 07, 2012 7:08 pm
How about you mount your wheel to a scissor jack, then have a pocket for the jack to fit into on the bottom side of the tongue?
dave_dj1
Postby Rhino Ray » Sun Sep 09, 2012 12:17 am
I have a bit of a problem with my rear leaf springs sagging on my Chevy so I use my old bumper jack to lift it high enough to fold down my wheel. I also use it to jack up my TD to level it. Works great! I'm getting new springs soon.
The eleventh commandment: Ye that snoozeth loozeth. Selling real estate in ALL of Jefferson State (Northern California and Southern Oregon)
My Build http://www.tnttt.com/viewtopic.php?f=21&t=49746
Rhino Ray
Images: 60
Postby KCStudly » Mon Sep 10, 2012 5:15 pm
I was thinking that maybe an over center lever style jack (kickup style?) like the old Indy cars or racing motorcycles use. Prop it under the frame, step on the lever to lift and it locks in the lifted position due to going "over toggle", stuff your existing pony wheel under your existing jack and crank away. Once the existing tongue jack lifts off of the lever, pick it up off of the ground and walk away.
Nothing to modify so your classic camper stays original, and only a thin light device that could stow virtually anywhere. Might even be pressed into double duty for a lantern stand or tire change jack if you design ahead for it.
Think like the Egytians, leverage is your friend! :thumbsup:
Well, I see now that you have no jack at all, so let me revise that. Stick it under, step on it to lift trailer off hitch, move car, lift light long end of lever to set back on pony wheel?
Maybe not as practical as I first thought. :NC
Users browsing this forum: Google [Bot] and 16 guests
