Zollinger wrote:Winter camping is not for everone. You must be prepared. We enjoy it because usually we are the only people in the park. It's nice sitting around a campfire while the snow gently falls around you. "No screaming dogs or barking kids anywhere in sight!"
jfocallag wrote:Thanks for the information. I wish I had seen it before I went camping this last weekend. It was definitely much warmer near the ceiling of the camper. I thought about how you reverse a ceiling fan in order to push the warm air down during the winter. A small fan in the camper will do the trick. Thanks again.
streetrod23 wrote:Hi we have camped in 25 degree temps in our tear. The roof has an inch of foam insulation thats it, nothing in the walls. We had a very small electric heater ( car warmer style) if you know what that is haha. It was toasty warm. We had to turn it off a few times as it was too warm. We did leave the roof vent open slightly to vent the humidity. No issues other than the darn water left outside was frozen and I didnt get my coffee right away. By the way were jealous...Its -4 deg f here so our tear is put away until May....Good luck
Hey I see your from Wisconsin, you know what a car warmer is..
Bogo wrote:For the real polar bear campers.
Starting a pesky truck in a remote area on a -20 morning can be done.
Starting a pesky truck in a remote area on a -20 morning can be done. Take your camp stove, light it and slide it under your engine. You need enough ground clearance so you don't have the stove to close to the bottom bits of the truck. A high ground clearance vehicle like Toyota 4x4 Pickup or 4Runner is perfect for this. Once you have the camp stove under there and lit, then block any wind from blowing under the truck. Let it heat up the truck for a good 30 minutes. To temper the heat some, a heat spreader like a skillet can be placed on top of the stove. If you want, you can even heat your breakfast while you are heating the engine. I'd use a covered skillet.Some pre planning could allow the technique to be used on a vehicle that wouldn't have enough ground clearance. The vehicle could be parked on some ramps to lift the front end. Snow cleared from the parking spot could be used as a wind break. When I went up Aurora watching I carried a fully charged battery as well as some large cardboard sheets to use as a wind break.
Of course if your truck has any oil leaks under the hood, I'd get them fixed before using this technique.
I've never needed to do this as my Toyota 4x4 Pickup has always started at -20, but I have tried it out once using my MSR camp stove. A few years back when we had a 0F cold snap here I tried it out in the driveway. I lit the camp stove, and then used some cardboard sheets to block the wind. After 20 minutes of heating my pickup started up like it was in the 40s out. I've also used it on tractors out in the field.
BTW: I got the idea for this from a show on living in Siberia. At one point they showed them with a fire under one of the trucks. The fire was to keep the engine warm so it didn't crack the block or other parts when started. A little over mid way down this page is a photo of some trucks with fires under them. http://www.marxists.org/history/ussr/ar ... y/workers/
Here is the photo:
alaska teardrop wrote:This method is used in the far north to warm up planes & vehicles safely when there is no electrical service.
A weed burner connected to the propane tank & six feet of 6" furnace pipe w/elbow. This picture shows the set up, except that the weed burner is layed on the ground w/the nozzle just inside the pipe. The flame doesn't reach the truck. A blanket of some sort can help.
Users browsing this forum: Google [Bot] and 11 guests
