Bogo wrote:Same place has a similar 40W panel @ $55 each.
notned wrote:I have the idea that the trailer (Lights, fan) should be hooked to the load side of the controller, but I'm having trouble thinking of how this would tie to the tender.
notned wrote:Fantastic fan. 3 amps. 2 led bulbs and one regular bulb. By my count that's ok,right?
Will my led bulbs be ok? I read some stuff about higher voltages that has me spooked.
Thanks for the help.
I got the sun saver 6.
bdosborn wrote:LEDs are voltage sensitive, meaning a small increase in voltage burns them out quickly. Your new solar panel and the battery minder is going to supply 14.4V to your LEDs and they'll burn out if they don't have a regulated power source that Bogo described. I always check the voltage rating of the LEDs I buy. If it gives a range like 12V-15V then I buy them. If it lists 12V only I don't buy them.
Bogo wrote:Actually LEDs are heat sensitive.
<snip>
There is a maximum voltage that the LED can handle, but it isn't an issue with only slight over voltages.
Bogo wrote:How long are your camping trips? Do you wish to camp where there aren't electrical hookups?
While I've planned for solar, and figured on possibly 70 to 100 watts initially. I've always figured that my first step would most likely be a Honda generator powering the onboard converter/battery charger to recharge the batteries. After that, then I'd get a solar panel set. In the past, price wise, it was hard to beat the generator method, but now with solar panels so cheap... I haven't run recent cost for capacity calculations. Something also to think about is if we get out of this recession, gas and diesel prices will jump as demand goes back up.
