We will be testing ours on the shore of Lake Superior this summer, tree covered and I an anticipating I may actually have to use our Unisolar 144 W flexible panel (18' long) as everything will be powered from solar.
Shadow Catcher wrote:Bruce I thought you had more than you could useHow many do you have?
bdosborn wrote: We could skip watching movies in a pinch as that's the number one energy user in our trailer but what's the fun in that?
GerryS wrote:I agree. Totally impractical. Too many problems to even consider. Stability in winds, fragility whiling pulling, complex setup, not to mention if you don't use the pneumatic of hydraulic this'd seals go bad fairly quickly.
A small generator will produce more power, cost less, and per kw/h is probably more efficient than the panels.
It costs a mph or two to pull the extra weight, not to mention the energy it took to build. You might use it ..45-60 days a year if you camp a LOT. That's about 600 gallons of gas for a generator. What? $2500? How much does that monstrosity cost? Over 5 or so years....
Nah, a Yamaha 2400 is 52 db and costs $1800.
No contest. Unless you're off grid full timing, then MAYBE it would make sense. But not even for the hard core camper...
eamarquardt wrote:Yeah but generators just don't have "cool factor".![]()
