by Wolffarmer » Mon Jul 22, 2013 9:33 pm
Shoot, don't over think the problems. Just taxes your brain and for very little gain. Put new ball on and tight it up as best you can with what you have. If it makes you feel better use a bit of Locktite on it. Doesn't really matter which one both will do the job, really. The high strength one will probably need to be heated up to remove if you ever wish to. ( actually no probable, it will need to be heated ) But most important. TAKE THE WRENCH WITH YOU AND OCCASIONALLY USE IT. Also if there is a split lock washer on it those can be over tightened and break and guess what. Your bolt is now lose, very very lose. If you use locktite you don't really need a lock washer. On my 1981 Datsun Pickup I put an extra leaf in the rear springs years ago. No new longer u bolts to be had to fit it so I just tossed the lock washers and used Locktite. That was almost 200,000 miles ago and many many times over loaded. I decided to stop worrying about it. No need to replace the receiver or the coupler, They did their jobs. Your clearance light problem may not even be related to this. Yeah, get a better set up for the chains.
Randy
