Condensation questions
Re: Condensation questions
Postby tony.latham » Mon Nov 25, 2013 1:40 pm
12v mattress pad.
Postby KCStudly » Mon Nov 25, 2013 3:45 pm
Postby kd5edj63 » Mon Nov 25, 2013 5:10 pm
KCStudly wrote:Votive candle furnace linky.
Thats a very old thread with many replies. Can you dirrect me to what you are refering to exactly
kd5edj63
Postby kd5edj63 » Mon Nov 25, 2013 5:11 pm
tony.latham wrote:12v mattress pad.
Where would I find a 12v matress pad. That should kill a marine battery in a matter of hours I would imagine
kd5edj63
Postby kd5edj63 » Mon Nov 25, 2013 5:22 pm
I found a matress pad on amazon but i wouldnt be able to pin it to my air matress. But thanks for the tip. Not ruling that out as an option :thumbsup:
kd5edj63
Postby KCStudly » Mon Nov 25, 2013 9:22 pm
kd5edj63 wrote:
That's a very old thread with many replies. Can you direct me to what you are referring to exactly
re: Heating a TD. The thread has been active again lately starting on pg. 2. Unfortunately in the time since I posted here, Mike had been posting some cold weather test results, and they were unfavorable for the candle heater in an uninsulated pod. Maybe it would do better with insulation. Many of us were hoping for a simple, inexpensive and safe method to heat our small spaces, and Mike has just posted some real world test results for a couple of small heater options.
Read it if you like.
Postby tony.latham » Mon Nov 25, 2013 11:29 pm
I recall six amps on mine. I just use it to preheat the bed.
There is no bed colder than an air mattress. Convection.
Postby kd5edj63 » Fri Dec 20, 2013 12:10 pm
tony.latham wrote:My 4x10 Hunter has 1/2" plywood walls and almost always got condensation unless the window were cracked at least a half inch. I recall some hoar frost one 11ºF morning. This photo shows it at about 30ºF:
My new home-built with the 1" walls and 3/4" of insulation doesn't get condensation on the walls that I've seen yet, but I still get the moisture on the Frank Bear glass doors (that I really like). Either way, you really need to ventilate your teardrop to stay alive. I'm not convinced varnish seals the wood completely, but my interior has three coats of poly and crossed fingers. I never did get any water damage in the Hunter. When it got really damp, we wiped the walls down with towels.
But spend $16 on that gizmo, take it on a shakedown cruise and get back to us!
They dont take care of the problem. They are more a storage solution. I think I will just get a good chamoise and do a wipe down each morning
kd5edj63
Postby tony.latham » Fri Dec 20, 2013 5:41 pm
If I recall, my double sized mattress pad pulls 6 amps. I only use it to pre heat the bed.
TL
