Rob, to answer a previous question, the asking price right now is 1200. It it basically a new trailer frame and axle, newer jeep alloy wheels, newer 31" BFg at's, doors, vent, the leakproof galley hinge, etc.
He is saying the plywood is not delaminated and it's just the rough side of the plywood. Assuming this is the case and I check it out before I buy it) Would it really be a big deal to pull the roof and galley skin, check for mold, insulate, replace the Masonite if necessary and skin it ?
Good trailer, good profile, good frame, but it think the builder's rush to finish it has let him down.
It looks like the builder didn't put the time and money into doing it correctly, and is now left with that. Don't make the same mistakes he did.
I'd be pretty weary of mold and mildew. Its not impossible to get rid of, but you're going to spend more time and energy trying to battle it than you would just starting over. Adding cabinets and cupboards will require solid wood to attach to. Hopefully the sides are not too far gone to do so. The damage looks deep
as it sits now, you could definitely make it watertight and usable for a few years, but for all that expense and effort, you will always have a cobbled-together low-quality build. Is that what you want?
but the seller either isn't being straight with you or just doesn't know what he is talking about
Dale M. wrote:Buy it.... Do temporary repairs for trip and then this winter fully repair/restore it when there is not a time crunch...
Dale
48Rob wrote:Oz,
Thanks for posting and clearing up some of the gray areas.
The frame does look well built, and you are right in that the new buyer can either repair, or start over.
In the end it will make someone a nice trailer.
Mike just has to weigh his skill level against the potential cost to repair or rebuild and determine if this trailer works with his time crunch and budget.
Rob
PaulS wrote:Dale M. wrote:Buy it.... Do temporary repairs for trip and then this winter fully repair/restore it when there is not a time crunch...
Dale
Like dale said buy it there is plenty of help here for the questions that you have and there is a lot of good stuff that you could reuse even if you tor it apart and rebuilt it over the winter. Are you in the metro Detroit area mike. If so I may even be able to help you
