The canopy you linked is of a size that could often be quite nice. It is also long & heavy enough to make erecting more difficult than a 10x10, especially if you ever have to do it by yourself. It's heavy enough to make getting it into & out of the tear drop more of a hassle. None of that may apply to your situation. Just thought it worth mentioning. Not knowing the brand I cannot comment on how well it's built or how strong it may be. It appears to be constructed similarly to my EZ Up which has proven to be quite sturdy.
We have a 10 year old, 8x8 First Up like BobHenry's and a 4 year old, 10x10 EZ UP Pyramid II. Both have been through multiple situations with sustained winds of 20+ MPH and gusts of 40+ MPH. Neither were damaged while some other peoples canopies were shredded or sent flying away. It isn't what I'd suggest doing but when you have a vendor booth set up at a weekend event & leave for the night you sometimes aren't given a choice.
For anchoring I've found the heavy duty stakes marketed by EZ UP work extremely well with my 10x10 EZ UP. Can be had in sets of 4 or 6.
http://smile.amazon.com/E-Z-UP-Stakes-Set-6/dp/B002VUBC7M These are 14" long & very sturdy, we pound them in with a 4 lb hammer. In addition, we use tie downs and weights, 20-40 lbs per leg. With the new (to me) camper I will tie down one side to the camper itself, similar to BobHenry. The other side will still be done my usual way. Weights have varied over the year from 40 lb cinder blocks to multiple 20 lb kettle bells to several gallons of water per leg.
Remember that wind blown canopies can badly damage vehicles and injury people. At a dog event, one participant had her canopy fly up & crash into her SUV causing $2000 damage. Thankfully the dog crates were sturdy enough to protect the dogs when the legs of the canopy hit the crates. Thankfully no humans were close enough to be hit.
Edit: Forgot to add that having full sidewalls can be a double edged sword in winds. If you have them all zipped fully shut it greatly limits the amount of wind that can get up under the canopy, reducing lift. At the same time though, those walls can act a bit like sails. Still, my EZ UP seems to fair wind better with the sidewalls all zipped up than without the sidewalls.
