Small Truck Campers
Re: Small Truck Campers
Postby rowerwet » Fri Feb 27, 2015 7:05 pm
I would just build one the way I wanted, this site is full of people who build and we would be glad to help with construction and material ideas. :thumbsup:
rowerwet
Images: 521
Postby DrCrash » Fri Feb 27, 2015 7:13 pm
I second build it yourself. Lots of good info here .
I would also like to throw out dont buy " Paul Butlers" camper plans they are a compleat rip off.
Glenl plans are good for the 40 some odd bucks they cost.
DrCrash
Images: 51
Postby boomer » Sat Feb 28, 2015 4:24 am
I think building one will be my only option. I'll have to turn the heat on in the garage and get some measurements. Thanks for all of the advice, Ed.
boomer
Postby PaulS » Sat Feb 28, 2015 6:01 am
If you go to the Glen L site and look at customer pics there is some that show the framing if you want to see how they did it
PaulS
PaulS
Postby rowerwet » Sat Feb 28, 2015 6:31 am
If it were me I would look at the foamie section, then build the part of the camper from the bed rails up with 2" foam. With some wood framing for the doors and windows, and roof rack mounts. Your camper shell would be super easy to heat or cool, quiet, and light weight.
Foam would also be easier to sculpt into rounded shapes to match the syling on modern trucks. :thumbsup:
Even if you don't like the idea of foam walls and roof, you could just splice some foam in at the corners, then fiberglass over the whole top once you got the profile you wanted.
make sure you share picutures :pictures: if enough people like your build I could see this being the start of another section for tnttt! "Truckers!" :lol:
rowerwet
Images: 521
Postby daveesl77 » Sat Feb 28, 2015 7:24 am
Having had one I can tell you that by building it yourself, you'll get exactly what you want, it will be far better than any factory built, weigh much less and cost less. In reality, it is far smaller and less complicated than a TD.
dave
daveesl77
Images: 273
Postby daveesl77 » Sat Feb 28, 2015 1:18 pm
Here is our old popup truck camper.
128981
dave
daveesl77
Images: 273
Postby KennethW » Sat Feb 28, 2015 2:47 pm
Here is a different pickup camper :thinking:
http://www.quickupcamper.com/
If you would like to build :roll:
http://www.quickupcamper.com/howitsmade.html
KennethW
Images: 82
