UK-Corlett New design New build
Re: UK-Corlett New design New build
Postby Java Jack » Fri Mar 20, 2015 2:05 pm
Interesting design. Will watch this one to see how it comes together.
I tried searching for Paddlehead but nothing comes up. Is there a build journal on that project?
There are 10 types of people in this world, those that understand binary and those that don't.
Regards,
Java
Proud Owner of a CampInn 560 Ultra
Blog: http://cre8tiveapps.blogspot.com/
Video: https://youtu.be/TLLFt3vzFoA
Sill Images: http://imgur.com/a/EE0zC#0
Java Jack
Postby Vedette » Fri Mar 20, 2015 9:42 pm
UK-Corlett wrote:I have just got this delivered, I think I am committed to the build.
What is it?? :oops:
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Postby UK-Corlett » Sat Mar 21, 2015 10:17 am
Hi java jack
Very similar to yours
gallery/album.php?album_id=2076
Later I may ask you about your curved windows.
Clive
Hi vedette
Its a thicknesser
A wide planer with a motorized feed.
Very good finish, very accurate thickness, very expensive; I also have a bed and twoo exterior hard wood doors to make.
Clive
UK-Corlett
Images: 220
Postby Greg M » Sat Mar 21, 2015 10:30 am
Brian, you wouldn't recognize it, because it's for wood ;)
Clive, that's going to be an interesting and challenging build; I look forward to watching it.
Greg M
*Geek Extraordinaire
Images: 85
Postby Vedette » Sat Mar 21, 2015 10:41 am
Greg M wrote:Brian, you wouldn't recognize it, because it's for wood ;)
Thanks Greg & Clive
Thought it night be something like that??
Yes, woodworking is definitely not my Forte! :cry:
Clive have you google imaged those Chev PU corner windows yet??
Brian
Good Roads
Brian & Sandi
Vedette
Images: 443
Postby dales133 » Sat Mar 21, 2015 10:42 am
Love the thicknesses I've been showing much restraint at not getting one myself but my trusty table saw has been invaluable with my project
dales133
Postby UK-Corlett » Sat Mar 21, 2015 2:40 pm
Hi vedette
Yes that's the kind of thing, I may want something bigger.
However watch this space. After I have been working on the dam thing for 6months I may be cutting corners.
"Ambition is the folly of fools and youth"
Your fool, Clive
UK-Corlett
Images: 220
Postby mezmo » Sun Mar 22, 2015 4:00 am
Hi Clive,
I can appreciate your desire to build for a "look" as well as practicality.
I just personally gravitate to practicality first, then "make it look good"
afterwards.
A Kammback is an automotive based design named after it's Austrian
auto engineer originator. The most aero efficient design is the teardrop
shape with a long tapered tail on it [To an endpoint.]. Applying that to
autos wasn't very practical for use. Kamm discovered that you can still
garner almost the same amount of aero benefit if you cut off the tapering
tail [Again taper not greater than 15 degrees.] at the point along it where
the cross-section is equal to about 50 percent of the maximum cross-sectional
area of the preceding body structure. Here is a link to the Foamie Section's
Aero thread, that has more on that and some other info that may, or may not,
be useful for you with your build: http://tnttt.com/viewtopic.php?f=55&t=49036
And angib is a UK member of the forum here, who's an engineer, and also has
a section in the Design Resources area.
Norm/mezmo
mezmo
Images: 194
Postby UK-Corlett » Sun Mar 22, 2015 8:08 am
Hi mezmo
Excellent reply. I will do some research.
Car designer have used spoilers to achieve a similar thing. I wonder if there is a half way house.
I have seen Autodesk Flow Modeler used I think I will have a go. Better the devil you know.
Clive
UK-Corlett
Images: 220
Postby GPW » Sun Mar 22, 2015 8:29 am
It woulds make a nice Foamie' too with a bit of “engineering” ... :thinking:
