What makes a TD project unsellable?
Re: What makes a TD project unsellable?
Postby aggie79 » Mon May 11, 2015 2:12 pm
cometgv wrote:I went overboard on some things that added a lot of cost. For example the axle/wheels/tires/fenders/rings/caps were very expensive but I wanted to get that "look" so it was worth it to me.
I think these expensive "add-ons" are important to highlight. It has been awhile since I purchased them but I believe I have about $1600-1800 in wheels (including rings and caps), whitewall tires, and fenders alone. I don't believe the average teardrop buyer understands what these cost.
Postby Socal Tom » Mon May 11, 2015 3:37 pm
It might make sense to sell the extra add-ons separately if they are adding a lot of cost.
Socal Tom
Postby mrwall1 » Tue May 12, 2015 12:31 am
Sad to see a slow sale... We all know how much time and costs go into building one! I know when I first saw one, I wanted one, when I saw the cost to buy one the idea flew out of my head... all I could think of was I could get a nice used larger Travel trailer for less... But then I saw Youtube videos of people building them... then found the forums here.... Looking back... I thought I could build one pretty cheap... of course I found out.. even with my simple build it has cost over $3500 and a lot of hours.... of work... and that is not counting all the extras like mattress, Locks, stoves, coolers etc.... also I think financing is an issue, you can go to an RV dealer and walk away with almost any trailer for similar price for under $100 a month... Private sales require cash.....
Good luck! keep us informed on your sale!
my Old Teardrop build journal
viewtopic.php?f=50&t=59792
My New 7x16 Continental V Nose Build
viewtopic.php?f=42&t=67734
My Photobucket Link to 7x16 V nose build
http://s20.photobucket.com/user/mrwall/ ... %20Trailer
Mike
mrwall1
Postby fullon627 » Tue May 12, 2015 10:35 am
I agree with Danny. That stove/sink are pretty much useless and the stove is dangerous. When you have that beautiful curve front end on your teardrop, why do you have a flat wall inside? Seems like your losing a lot of space. It does look nicely built besides that.
It's a great world if you don't weaken!
Boats float and airplanes fly!
If you boat sinks you can swim!
If you airplane falls you can't fly!
Ken from Eureka Ca.
Boo's Build viewtopic.php?f=50&t=60867
fullon627
Images: 283
Postby captbobh2o2004 » Tue May 12, 2015 11:40 am
Your Rig looks Great! We have several builds going on in or around Albuquerque and I have a pal in Md. on his 3rd. Not that any of that matters, I think like a few others on this site "Price" Folks around here seem to think $3000 - $4000 might move it. Good luck :thumbsup:
captbobh2o2004
Postby Socal Tom » Tue May 12, 2015 12:00 pm
I just noticed the door on the DS is rectangular, but the cutout on the PS side has a curved top. How will that be addressed?
Socal Tom
Postby Kharn » Tue May 12, 2015 2:22 pm
Everyone thinks they can work with wood, and most can do a good enough job to make a functional tear.
Aluminum, especially if structural and/or involving rivets/welding, is beyond most builders and they realize it.
A door on the driver's side only is also a big downside, especially for a 5' wide.
Kharn
Postby cometgv » Wed May 13, 2015 8:39 pm
All good questions!
THE DOORS: I originally designed the door frames with nice radiused corners. Later on I discovered that the T molding would jam up against the trailer body when the door is opened. My solution was to cut the frames out square and build new doors to fit. It worked out great....no interference and the doors close nice and solid like a car door. Also, there is now a door on each side with vintage aluminum windows.
THE WALL: I took a sliver of the front and enclosed it with a bulkhead because I wanted an electrical compartment. I stretched the body a few inches to recover the lost space. There's an access port in the front which I haven't cut open yet. Inside the cavity is where all of the electrical wires come together so I think of it as a utility room of sorts. It's supposed to have an aircraft style access cover on the outside when done.
EXTRAS: Thanks to you guys I've been inspired to pounce on this project and get stuff done. I spent some time inside and hung the cabinet doors. Also took it to the local certified weighmaster and it comes in at 1,220 pounds. Whew! no brakes required.
I sure wish I would have found this forum several years ago!
cometgv
Images: 11
Postby Vedette » Wed May 13, 2015 9:16 pm
Good choices! And good clarifications!
You are acting like a motivated seller, which should net you a better chance of a sale. :thumbsup:
Good Luck
Brian
PS
Hope you get to come back to us someday if you do sell this one.
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Postby Socal Tom » Wed May 13, 2015 9:18 pm
Sounds great. At this rate you may want to keep it.
Socal Tom
