I just started looking at Kayaks and trying to figure out what would work best for my wife and I. We are pretty set against Sit On Top models as they just seem like they would drag a lot on top of the water and be hard to paddle on a day trip. Therefore, we are looking at the sit inside designs.
So, uhhh, Java-Jack, tell me, how can you be set against something if you don't know or understand what that something is?
Sit-on-Tops ( SOT ) are generally wider than sit-inside kayaks ( SIK ) making them more stable than their skinny brethren.
The Sky is 10' long & 26" wide, has a capacity of 250#, weighs in at 32#. because of it length, tracking may be problematic & my be tippy at 26" wide.
The Rio is 12' long, 24" wide, has a capacity of 270# & weighs in at 35#. should track well but at 24" wide, it may be tippy for a novice.
The Caribbean 12 is 12' long, 30" wide, has a capacity of 300# & weighs is at 45#. At 12' it should track well & will be pretty damn stable at 30".
I have not paddled the Sky nor the Rio, I have paddled the Caribbean 12 and can tell you it is easy to paddle and does not "drag" on the water.
Matter of fact, this l'il boat is pretty damn quick!! I've fished out of one a couple of times & it's as stable as the day is long!!
At 45# it is easy to put on top of the car.
The SOT's are
not barges because of their hull design. 99.9% are fast as hell and make day trips easy & enjoyable.
I'm thinking you may not want to judge a book by it's cover...
Daniel ( "dexstrom" ) is 100% correct - get out and test paddle some boats. Demo boats and rental fleets are being sold this time of year and at very affordable prices ( like 50 cents on the dollar ). If the kayak shop won't let you test paddle then walk away & find one who will.
Good luck!
Charlie
