Sealed Battery Ccmpartment or Box?
Re: Sealed Battery Ccmpartment or Box?
Postby Vedette » Thu Aug 13, 2015 10:34 am
Not a fan of AGM Batteries. :roll:
But, a small to tube or upper vent is note a problem( as it can vent out into a wheel well) and if the top is sealed to the inside of the TD then water from the bottom would probably not be an issue.
But, thank you to everyone who has responded to this thread, as it has give me much more food for thought and some new ideas.
Good Roads
Brian & Sandi
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Postby martymcfly » Thu Aug 13, 2015 12:01 pm
I would like to remind you all that the most successful ever produced (vw beetle) had a battery mounted under the seat, with metal springs, inside on the passenger compartment, with an ashtray less than 18 inches away from it. Seemed to have very little problem with fumes. Although I have seem a few with some serious rust in that area.
martymcfly
Postby darrellbeck » Thu Aug 13, 2015 2:08 pm
[quote="MtnDon"]All that seems normal. Battery fluid levels get neglected all the time. When charging a depleted battery bubbling noises are common. The battery is not boiling, it is producing hydrogen and oxygen because of the charge current. I have a bank of 12 batteries at our off grid cabin and they can make quite a racket when the sun shines brightly and they are partially depleted. It sounds like the converter / charger cooling fan was running [quote]
Mt Don, can I ask what field you were in during your working life? You seem to have an accurate answer to most of the questions asked on here and I am just curious.
darrellbeck
Images: 24
Postby MtnDon » Thu Aug 13, 2015 4:31 pm
Working life;
auto parts warehouse ; from gofer to assistant manager
retail camera store, assistant manager and purchasing agent
playground equipment manufacturing company; my own start up
for a large large bank, check & debit card fraud investigation
Mix into that an interest in things mechanical and electrical with 3 years in engineering school (but no degree :( )
built and raced drag bikes and trials dirt bikes
club sports car racing,Production, FVee, FF and GT classes , (SCCA)
lifelong interest in 4x4, mostly Jeeps
Interest in construction and design, did our house and cabin
MtnDon
Images: 24
