Northern Tool trailer 45 mph limit
Re: Northern Tool trailer 45 mph limit
Postby elcam84 » Thu Dec 15, 2016 12:11 pm
Roly Nelson wrote:The ratio of the spindle dihedral, the roadway temps and humidity, coupled with inverse quadridupled conflagulation, could spell trouble. Just kiddding! My HF trailer has 35,000 miles on it, 3 new sets of tires and absolutely no problems whatsoever.
Roly, the So Calif woody guy :?
Yeah spacers are a not a good idea but I'm going from my ase tech background and they are a bead deal on cars. Their big issue is that the larger inner bearing takes most of the load. As you move the tire out further the load is transferred to the outer very small bearing. Spacers have other mechanical issues there as well.
On fwd cars it's much worse because the bearings are smaller and they are well known for short service life in a non abused situation.
But on these small trailers that I doubt any will see any load near the rated capacity by the owners here I guess it really isn't an issue.
I finally saw my first 4x8 hf trailer on the road a couple weeks ago. They don't seem to sell well here. Course few here would be caught dead towing one of them behind their 70k $ truck....
Sent from my SM-T320 using Tapatalk
elcam84
Postby lacustom » Mon Jan 02, 2017 10:36 pm
m
Roly
What is the weight of your trailer and tounge weight?
How often do you repack your bearings , do you use red hi temp grease?
Just built a TT on a HF trailer, now that it's done I was questioning the tires
Any info would be appreciated
Lou
Lou Piscitelli
If you can dream it ,we can build it!
lacustom
Postby lacustom » Fri Jan 13, 2017 10:33 pm
Slow
What is the tongue weight of your trailer?
Lou Piscitelli
lacustom
Postby dguff » Sat Jan 14, 2017 11:42 am
If the trailer manufacturer recommends a 45 mph maximum then you should build in a safety margin and not exceed 35 mph. :lol:
Jerome
2008 Guffman
dguff
Images: 69
