That's our "utility room" in the front of the teardrop. The bulkhead (aka, our headboard) is one and a half inches thick, skeletonized foam, which hopefully cuts down a little on the noise of the unit. (At ~70 lbs, It's too heavy for us to want to move it outside.) There will also be a barrier directly above the AC unit, of similar thickness.
We will have utility doors on the front and side, and the one on the front will be on gas struts, so they will be left open to ventilate the AC.
I haven't screwed the plates into the bulkhead yet, this was just a test fit to see how the duct will run.
So the guy in the video mentioned the holes should be 16" apart. Ours are only 6" apart, because I couldn't figure out a better way to do it. We will test it like this, and also with the return duct left off, so the AC gets air from the outside (and we have a vent to the outside).
I have to cut these to fit (of course) and we will use closing louvered covers. Maybe with them directed in opposite directions it will work with the return duct.
The Climateright has a drain hose at the bottom, and I'll drill a hole. I'm wondering about the output duct collecting condensate, but it will be a few years before we travel to a humid enough climate to test that one.
