Generators
Re: Generators
Postby Bill n Robi » Wed Jun 19, 2019 2:21 pm
My Yamaha converted to propane is quiet, no smell. only H2O and CO2 for exhaust, mixture adjustable so it has worked from -120feet to +6100 feet at peak performance.
2015 T@G Max
2015 Toyota Tacoma TRD Sport 4 Door Short Bed
Bill n Robi
Re: Generators
Postby Socal Tom » Thu Jun 20, 2019 7:48 am
GuitarPhotog wrote:
Dahlia47 wrote:For the harbour freight generator, how long will I be able to run the little window a/c unit?
And what does it mean when the description says "running at 50%?
I don't know anything about electricity or engines. I can make just about anything out of metal and wood, but when it comes to electricity and engines, I am so lost! Ugh!
Thank you!
The HF generator is a good deal, but... It is not repairable, there are no repair parts available. You can buy an extended warranty, and can return a defective unit to a HF store for replacement, if they have it in stock. Which they haven't had in my local store for the last FOUR MONTHS!
If you want true simplicity in a generator, find a 2KW dual fuel generator that runs on propane and gas, then never use it on gas. You will not have to empty out unused fuel, nor clean a varnished-up carburetor, nor deal with gas going out of date (gasoline lasts only about 6 months in a can these days).
The HF predator is a rebadged WEN
https://wenproducts.com/collections/generator-parts
I run my 5k btu fridgedaire off of a 1kW Honda , personally I recommend using a 2KW generator . They can so much more, only weigh a little more. The HF has good reviews and a good price. Most small gens will run about 8 hours on a tank depending on load. There are ways to increase tank size that don’t break the bank if needed.
Socal Tom
Re: Generators
Postby GPW » Fri Jun 21, 2019 12:46 pm
Hi Guys , we got the Harbor Freight 2K generator just to run a small 5Kbtu AC , not only for the EVAC trailer , but also for “Sheltering in place” with No power ( Hurricane season) … Having no use for it yet , we never took it out the box , but I digested the manual thoroughly , plus about 219 You Tube generator videos ( Thanks Mustie 1 ) … I have all the other things to go along with it , Gas , Oil , tool kit , spare plug ( ? ) , siphon hose for my Truck … Pretty standard stuff …
And if that don’t work , we have a few Solar panels ,charge controller , DD storage battery etc … Something , anything that will create a Cool breeze on the Wife …. ;) You know , gotta’ take of the Wife eh !!!
Re: Generators
Postby Dahlia47 » Wed Jun 26, 2019 6:35 pm
I just got educated! I had no idea there was so many different types of generators. Keep up the good work. Thank You!
Dahlia47
Re: Generators
Postby Jiminsav » Sun Jun 30, 2019 8:49 pm
what ever you do, get a QUIET generator. harbor freight has a 2000 watt quiet one for 500 bucks.
Jim in Savannah
Jiminsav
Images: 40
