lfhoward wrote:I’m curious what strategy works best to keep warm...
- Ceiling vent cracked open a bit, windows closed all the way
- Ceiling vent closed, window (or both windows) cracked open a bit
- Ceiling vent cracked open a bit, one window cracked open slightly
The idea is to conserve heat, while allowing for fresh air (a fully closed up camper can kill you). Also, condensation can be an issue in the cold.
Which strategy do you employ? I know if I am plugged in at an RV park and can run my baseboard heater, I keep both the ceiling vent and a window slightly cracked open and it’s still nice and toasty. But I haven’t figured out what works best while boondocking.
We have a Propex in the raindrop. With the family in the trailer we sleep with the ceiling vent and both door windows open a few inches. We used the same method before the furnace, just used more blankets (wool blanket, down comforter). I made simple curtains for the door windows and vent, just two layers of cotton. It does slow down airflow a little bit, those ones are mostly to cut down on light and provide privacy. Our front windows are polycarbonate. Those ones get covered with same type of curtains that have a layer of Reflectix sewn into them for insulation. Our walls/floor/ceiling are all insulated with 3/4" rigid foam.
