Maybe it's no big deal or too expensive to convert to lithium from old style batteries.
Before purchase I'll dig deeper.
But here's an example of why I'm cautious and uncertain:
https://www.etrailer.com/RV-Converters/ ... 60ALV.htmlIn this link, note the Note: "Charge Wizard not compatible with lithium converter chargers.This converter charger converts AC shore power into DC power and charges your battery bank. The converter uses a higher voltage output to provide the proper charging profile for lithium batteries. If your RV already has a stock converter charger, it will need to be removed to ensure this unit operates properly."
Also, in the data per the link with etrailer.com:
Designed for Lithium Batteries
Built for lithium batteries, this unit uses a higher output voltage than a typical converter charger, which provides a fast, complete charge. The charger also extends battery life since it utilizes the appropriate charging profile. Additionally, it's compatible with your battery's internal Battery Management System (BMS), which helps manage charging by monitoring the battery state and balancing cell voltage.
