saywhatthat wrote:Fiberglass is heavy? Yes a full fiberglass trailer maybe heavy . with the RIGHT FOAM . the foam is the structural . the glass keeps you from putting your finger through the foam. again a wast of time and cash paints you can paint it with then use polyester resin, but make sure you use it right and enough of it. if you time gose for $.10 a hour you save some cash and have a weak piece of crap how Hard can it be use the right structural foam about $20.00 a sheet
GTS225 wrote:As a bit of a sidebar to this subject, I've wondered a few times how something like this might turn out in the weight department.
https://www.equipmentfacts.com/listings ... 1586475144
saltydawg wrote: Sure using a bedsheet and 15 lbs a gallon of house paint might be lighter but it would be very easily damaged as well as not strong enough for more than a 4x8 teardrop that never sees anything rougher than a pot hole.
Just my thoughts.....Roger
RJ Howell wrote:
I do take offense to a PMF foamie not being able to withstand more than a pothole... Each has their place.
This one happens to be 1000 gallons, but I've seen a 1600 up close, and it seems to me that it would lend itself quite well to a somewhat roomy camper shell. One would surely not need the running gear or pump systems, as it would never be carrying the weight of the fluid again.
Pros; Ready-made top opening for a vent fan.
Weatherproof.
(Probably) paintable.
Almost critter-proof. Even bears would have a hard time getting in.
The design of the understructure lends itself well to an internal floor install.
Cons; One would have to learn plastics welding in order to install a door.
No insulating value to the material.
One would almost have to paint it to keep from being disturbed at night by vehicle lighting.
Rounded walls won't help for internal finishing.
Material probably can't be glued to. (I suspect HDPE)
Buying one new would be prohibitively expensive, but if a guy could pick up a leaker on the cheap.......
Still.....so much is already done for a builder.
Squigie wrote:I think RJ finally worded things in a way that may change how I look at foamie construction.
I'm going to have to think about it a bit.
I may actually view foam as weaker, now, than I did previously.
