BufordT wrote:Yep. Something like that. Just use the same design layout only make so that you use a 4x8 sheet not 4x9
Let me see what you got.
Bufordt
So how wide are you building this time? 4' or 5'?
Bufordt
mikeschn wrote:BufordT wrote:Yep. Something like that. Just use the same design layout only make so that you use a 4x8 sheet not 4x9
Bufordt
mikeschn wrote:Something like this might work...
P.S. I would use 1x2s on all the joints between the wall and the roof, so you can screw into the pine and get a good strong joint!
mikeschn wrote:Hey Buford, you're way too easy...
There isn't much storage in there, maybe you could add a shelf above where your knees would be?
P.S. When you get your power back, you'll have to check out the photos I post this weekend. I am planning on building the roof panels this weekend.
Steve Frederick wrote:That's it! A camp kitchen, built as a mini version of your camper! The hatch would open to reveal your cupboards, stove or whatever. It could stand on pipe legs, threaded into the bottom. We had a kitchen box a lot like Len DaDonna's , when I was an explorer scout, a looooooong time ago!
