Designing a Puffie Standie?
Postby KDOG » Thu Aug 07, 2008 4:50 pm
Great work! I'm really watching these designs!
FAILURE TO PLAN ON YOUR PART DOES NOT CONSTITUTE AN EMERGENCY ON MY PART.
KDOG
Postby mikeschn » Thu Aug 07, 2008 5:56 pm
That folding arrangement could be similar to the Escape hatch door...
Oh yea, my back wall is supported during travel by a couple wall cleats...
Mstro wrote:Mike thanks for the lead - It pushed the thought process and this is the first thought to show - the fold would be opposite the Kampmaster, Laying down when the top folds, the hard part I see would be support in the door opening during travel, fearing wall flex. Challenging at best :? :?
Postby Mstro » Thu Aug 07, 2008 8:22 pm
That looks good Mike :thumbsup:
This should be how it would look on the mine
As you can see there is bracing for the wall in the galley and bunk area.
I think the area where i remove bracing can be reinforced for the more demanding travel areas
Marc
"Those who dream by day are cognizant of many things which escape those who dream by night."
Mstro
Images: 29
Postby mikeschn » Thu Aug 07, 2008 9:20 pm
I like it.
I don't think you need the brace across the door though.
Postby Mstro » Thu Aug 07, 2008 9:42 pm
Thanks Mike
You helped put me on different road and i like it :applause: :applause:
Now to fine tune and get going on making the real thing :thinking:
Hope to make a firm start soon :worship:
Marc
Mstro
Images: 29
Postby joecnc2006 » Fri Aug 08, 2008 10:59 am
mikeschn wrote:
mike what program do you use for the great looking designs, and also the nice pictures in the Benroy plans?
Joe
joecnc2006
Postby H@nk » Fri Aug 08, 2008 12:46 pm
mikeschn wrote:Doug,
Yes, I'd love to be able to have it fit in the garage. In terms of height, I'd probably plan on a dropped floor in the aisle, at least as an option. Then without the dropped floor it would be a slouchie.
Greg,
I'm interested in your cell phone pictures.
Puptent,
That sounds like the Generic ET! or the Tailgater... And that just too big to be a lightweight. By adding the bathroom, I have to give up the galley.
I thought about the tab profile too, but it's too hard to bend the plywood around the tail.
Mike,
Why don't you make the tail massive?
Or perhaps this one
http://www.adria-mobil.com/nl/products/ ... ion/341PH/
Very nice shape.
Old bread isn't hard, no bread, that's hard.
H@nk
Images: 81
Postby mikeschn » Fri Aug 08, 2008 3:17 pm
That would be Ironcad!
joecnc2006 wrote:
Joe
Postby mikeschn » Fri Aug 08, 2008 3:18 pm
Mstro wrote:Thanks Mike
Why not hinge the front panel right across the middle, and you can leave it attached permanently.
Of course I say that, but I haven't had a chance to look at that in CAD yet... it might not even be doable.
Postby angib » Fri Aug 08, 2008 4:54 pm
Marc,
Don't overlook the simple idea of just making the top of the door detachable - maybe with a couple of metal pegs sticking out from its bottom that fit into holes in the top of the lower door. If you've ever seen the sidescreens on an old Brit sports car, you'd get the idea!
That way you might be able to open the lower door even when the roof is down, which would be very convenient - the alternative is that you have to be able to raise all of the roof and side panels without ever going inside, which is a big ask.
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby mikeschn » Fri Aug 08, 2008 5:00 pm
angib wrote:Marc,
Andrew
I thought about that last night too. With the hinged door top, you would have to raise the top to get in on that side. A couple options are:
1) to put a small door on the other side.
2) to put a door within a door on the curb side
Postby Mstro » Fri Aug 08, 2008 8:05 pm
The front panel as it is envision it now will raise on glides as i lift the top and the sides when raised will wedge to hold everything up and square
Marc
Mstro
Images: 29
Postby Mstro » Fri Aug 08, 2008 8:19 pm
Andrew wrote
Marc,
Andrew
Andrew good to hear from you,
the pin idea looks good to stabilize the joining of the door half I think l'll use that during the build.
You through me a wringer with the door not opening part.
:? I had to double take a look and cam up with this possibily
the latch will lock the bar in place to the side framing and disconnect (looking at spring loaded bar) the door allowing the lower door to open :worship:
Marc
Mstro
Images: 29
Postby Mstro » Fri Aug 08, 2008 8:29 pm
Mike I did look at a small door in the main door, but I just cant' bring myself to do that. :(
Here's a couple more picks of what i have on the door assembly
Keep the brain exercises coming :lol: :R
Marc
Mstro
Images: 29
Postby KDOG » Sat Aug 09, 2008 11:41 pm
Awesome work guys. Do you think it would be possible to design a standie that would weight less than 1,000lbs?
KDOG
