Tom,
Since you were wondering about figuring out the details of strut installation, here's how I do it.
1. You want struts that will have a bit more force than the load they need to support. The load can be found with a bathroom scale and a stick. Pick a place where you think you'd like to attach the struts, put a bathroom scale on the floor of the trailer, and a stick between that point and the scale. The scale will tell you how much downward force the hatch is exerting at that point. The magenta line in the drawing below shows a weigh point that could be used for this hatch. Let's say the scale reads 40 lbs., two 25-lbs. force struts should do the job nicely, and 30-lb. struts would give a little more margin to protect from winds moving the hatch. (The stick in this photo isn't being used for weight measurement, it's holding up the hatch - this is just an edit of a photo I already had on hand).
2. Measure the vertical length from the attachment point you'd like to use on the hatch to the attachment point you'd like to use on the camper shell. Checking a website like McMaster-Carr, look for a strut that has that extended length and the force you came up with in step 1.
3. Check the compressed length of the chosen strut, the mount point for it will be a maximum of the difference between the extended and compressed lengths away from the hinge point. You don't want the strut bottoming out when the hatch is closed, so it's a good idea to make this distance just a bit shorter than the difference.
Those steps should get you appropriate struts for your application.
