Designing a Puffie Standie?
Postby mikeschn » Sat Sep 11, 2010 3:07 pm
Jim,
Agreed on the cooler weather. This summer was too hot to build...
Anyways, I am still planning on doing a Winter Warrior. If you are going to do a Puffin Standie, then we can get two sets of pictures with one stone!!! Which Puffin Standie would you do, with the galley, or without?
How soon do you need plans for my Winter Warrior Chassis to do it this year? (I know.... yesterday!!!) :oops:
Here I've added a vintage looking wheel cutout...
Postby Cliffmeister2000 » Sat Sep 11, 2010 4:21 pm
I like it!
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
My Teardrop build pictures
Cliffmeister2000
Titanium Donating Member
Images: 157
Postby mikeschn » Sat Sep 11, 2010 4:55 pm
So the question becomes, which one to do a set of plans for, for up there in the menu.
Something simple, that you can do on a HF chassis,
or something more difficult, that requires serious modifications to the chassis?
mike...
Postby doug hodder » Sat Sep 11, 2010 5:35 pm
Mike...if you do a step down entry...are you planning on a frame rail to step over only, or will it be raised from the exterior to the frame rail as well? I see a full height door, so makes me think it's just the frame rail. Doug
Postby mikeschn » Sat Sep 11, 2010 6:23 pm
Doug,
If we do the HF frame, it would be stepping over the frame rail only.
Postby Carter » Sun Sep 12, 2010 6:09 am
Mike I'll need the Warrior plans in May 2009, that's a big project and I'm slow. We'll talk.
The only 5x8 trailer I see on Harbor Freight is this one for $599
There's enough spare steel maybe you could figure out a way to make it into a true drop frame trailer.
There I go thinking again, always gets me in trouble.
I think that plans for the design library need to use a kit trailer or tractor supply no floor trailer.
If someone wants to build on something else they'll modify the plans.
The HF trailer is worth the money because it doesn't require a tongue jack. Look closely
Having a problem with my FTP site, Picture may not show
Jim
I need a new Avatar. I'd put my dog up there but she doesn't look much like me. She's the skinny one.
Carter
Images: 32
Postby Carter » Sun Sep 12, 2010 6:58 am
Sorry Mike. I see that's the HF trailer you talked about using on page 1
This is an idea I've been playing with
Back opens up to make a large awning
some shelves up top
Full width lower cabinet stores under bed (in yellow) and pulls out 2' to form the countertop.
This one has a 12' body but could probably be shrunk to a 10' on a 8' trailer
Carter
Images: 32
Postby mikeschn » Sun Sep 12, 2010 3:46 pm
Okay, so I am looking at the frame running through the dropped footwell for the first time, and I don't really like what I see.
So here's the question for you engineering types... Andrew?
Can I cut the frame where it goes thru the footwell, and support the frame with 2 or 3 bolts running thru the floor?
Postby angib » Sun Sep 12, 2010 4:12 pm
mikeschn wrote:Can I cut the frame where it goes thru the footwell, and support the frame with 2 or 3 bolts running thru the floor?
If you mean just stop the frame either side of the footwell and leave a gap, then no.
But I am always amazed at how little frame many of the fiberglass trailers have at their (one side only) dropped footwell. This is a Boler and I reckon there's half the frame strength at the footwell that there is elsewhere.
So you need a frame that goes down then under then back up again, but it doesn't have to be as big as the main frame rails.
angib
5000 Club
5000 Club
Images: 231
Postby Carter » Sun Sep 12, 2010 7:27 pm
Andrew,
I agree they look wimpy.....but there are several thousand similar trailers on the road and they seem to make it. Most everyone on this site over builds including myself.
Jim
Carter
Images: 32
Postby mikeschn » Tue Sep 14, 2010 6:11 pm
Okay, I'll look at a simplified dropped frame in the door area.
Postby GPW » Wed Sep 15, 2010 9:42 am
Do you really need a dropped frame ??? To stand up in one small area ??? Seems like a lot of trouble for so little ...Why not just make the trailer taller in the middle ? :roll:
Postby starleen2 » Wed Sep 15, 2010 10:30 am
I believe that the "puffin Clone" that was recently built had a step over? My next one will be a "stoopy" for me. I Found that 5'3" is an ideal height for the Mrs (5'0")and me (6'0") I can stoop good enough to put my pants on! :lol:
starleen2
5th Teardrop Club
Postby starleen2 » Wed Sep 15, 2010 10:37 am
here it is:
starleen2
5th Teardrop Club
Postby GPW » Mon Sep 20, 2010 10:31 am
Yet another standy' drawing ... :roll:
6' high , good for most (to put their pants on :lol: ) 6' wide to sleep sideways , 8' long to conserve on plywood ...
Figuring if you hung a clothes pole crosswise above the rear side windows , you wouldn't need any curtains ... :o
