Retro your TD with "Moon" hubcaps...
Postby TinKicker » Tue Apr 08, 2008 10:09 pm
Way back, s4son said:
Not to hi-jack the thread but; I went to the junkyard and got a “test” wheel this weekend. I wanted something with more backspace to pull the wheel in closer to the body. I thought I had measured everything and I printed out the list of bolt patterns found elsewhere on the forum. Found the wheel, got it home and the dang center hole was too small.
Last year I built a utility tilt-bed trailer out of a boat trailer, and had to get new wheels to replace the funky rusty bent chrome original ones.
As someone else said in another post, I'm not only cheap, I'm frugal (I don't own an oil well, so the gas prices are getting to me), so I went to a local junkyard and pawed through about two thousand old vehicle rims until I had what I needed: a pair of 13" Chevette rims! (4 on 4 bolt pattern)
The price was right...the owner felt so sorry for me having to dig so far and for so long that he gave them to me! :money:
Well, I got home, and had the same let-down s4son did: center holes too small. :fb
No problem. After calling every machine shop in the county I found one guy with a weekend home shop who had a lathe who could cut the centers out. Everybody else's lathes were too small and get this--he's only three miles from me! :awesome:
Oh, just to complete this perfect project, guess what he charged me? Since I'd sent him so much business before (all I knew was that he could build vehicle driveshafts--I work in an auto parts store), he did it for NOTHING! Who says there's no God? :angel:
The only trick was because of the nearness of the trailer hub to the frame, I had to mount the wheels backwards. That engineering involved actual bolts and some wheel wedges used on semi-truck wheels, but it worked. And the HUGE offset of the wheels from the hub looks pretty cool too! Painted and pinstriped them and I'm rollin'. :woohoo:
Only one issue to be aware of: a LOT of factory car rims are actually a double-layer design, and the two layers are perma-pressed together around the edge of that center hole. Cut the hole out, and there's a small chance the wheel will distort and pull apart while on the lathe. BUT if your machinist is prepared for that, he'll adjust the lathe speed accordingly to minimize destructive vibrations and you should be alright. :ok:
When I got my wheels back you could definitely see the two layers separately, but the lathe was run at low speed, and so nothing came apart. I've not had any trouble and it's already got a lot of miles on the trailer. :beautiful:
Happy trails.
Kelsey
__________
Go ahead and get your project started because it's just like having kids...if you wait to start until you're skilled enough or rich enough, you'll never do it. And just look at what you'd miss!
__________
In planning any project you've never attempted before, always allow for the three three's: It will take you three times longer, three times more material, and three times more money than you thought.
TinKicker
Images: 11
Postby doug hodder » Tue Apr 08, 2008 10:27 pm
I think that regardless of what hub cap/trim ring combo you come up with, it is a very important part of making your project have that "street appeal" CaseyDogs moons really fit in the opening well and is a great look on his tear. I also like Gage's as it has a retro 50's "lead sled" appearance to it. Others may disagree, but I think that your tear should have a set of wheels tires/caps that help set it all off. It's kind of one of those things, that when it is all said and done, you might find yourself saying "I wish I woulda"...I plan on lettering up the caps with the tear name on these. Doug
Postby rtp123 » Thu Apr 10, 2008 3:30 pm
Hi all:
I got the moon caps today from Hubcap Mike. I mounted one of the wheels (white spoked 15") to the dexter axle (with ez lube hubs) and put the cap on, it works!
The cap does not hide the red and blue stripes. I will post pictures as soon as I figure out how. :?
Still waiting for the frame to be welded together
rtp123
Postby rtp123 » Thu Apr 10, 2008 3:40 pm
Hi all:
The moon cap picture is posted in the album!
rtp123
Postby Kurt (Indiana) » Thu Apr 10, 2008 4:11 pm
rtp123 wrote:Hi all:
RTP, Lookin'good :thumbsup:
Nice "clean look" :applause:
CRA2023 Web Site
"Wall of Fame 2011-2021"
Kurt (Indiana)
Images: 178
Postby elmo » Thu Apr 10, 2008 4:30 pm
So it doesn't cover the red and blue strip, but it does look very nice!! I guess it is time to order a set!
It's scary when you start making the same noises as your coffee maker.
elmo
Images: 216
Postby AmyH » Thu Apr 10, 2008 5:43 pm
Yep, it looks much much nicer! :thumbsup: I think I will pick up a set for mine, now that I know what it will look like. A little further down the road I will probably paint the rims to match the roof of my tear, then the little bit that does show will tie in better.
BTW Doug, your teardrop builds always leave me speechless!! Even just looking at your tire rims with the moon cap and whitewall tires takes my breath away! That looks so incredible!! You have a great aesthetic! :thumbsup: Can't wait to see that build completely finished.
Amy
"...follow humbly whereever and to whatever abyss Nature leads, or else you shall learn nothing." T.H. Huxley
Photo Log
Camping Trips with the Tear
AmyH
*The 300 Club
Postby Pam Wright » Thu Apr 10, 2008 5:59 pm
A little late on the thread but I have smothies and baby moons on the Cherry Drop and love them!!! you can see them in my album, not a great picture, but they are shiny!
pam
Rocky Mountain TearJerkers
Director
"Be well, Be safe, Be Happy!"
Image"
Pam Wright
Images: 42
Postby caseydog » Thu Apr 10, 2008 6:03 pm
I have mine on white spoke wheels, and plan to take the tires off in the next few days, paint the rims red, and remount the tires. The moon hubcaps will look more authentic on red rims, I think.
CD
My build journal is HERE
caseydog
Images: 515
Postby 2bits » Sun Apr 13, 2008 10:30 pm
I've got Smoothies with white letter tires, maybe Smoothies are kinda standard for teardrops, but I am going to get them for my truck too so they will match. I really like the look, and the price can't be beat!
Thomas
2bits
2bit Member
