EPDM Roof with Living Hinge
Postby Todah Tear » Thu Aug 21, 2008 10:22 am
This thread and the photos have been a great help.
Where are you all getting the EPDM material for the roof? Would you post the p/n for the hinge that you got from McMaster-Car?
Thanks
Todah
Todah Tear
Images: 282
Postby Walt M » Thu Aug 21, 2008 1:34 pm
I'm not sure about Texas, but you could look for a Harvey Industries, or ABC Supply. you might be able to buy it from a commercial roofer who is willing to sell you a piece. I used a 5'x16' piece that worked well for me. I did it as one solid piece from front to back right over the hatch.
I'll check out the McMaster Carr Part number you want the heavy duty model. I'll be back in touch here with the number. Walt
All that is needed for evil to flourish, is for good men to do nothing.
Walt M
Images: 50
Postby mechmagcn » Thu Aug 21, 2008 1:39 pm
The # for the plastic hinge from McMaster Carr is 1588A731 and costs $5.38 a ft. I also got my EPDM rubber roof installed this past weekend, it worked out well as one piece over the hinge.
The piece of EPDM that I used was a leftover remnant from a RV roof job that I did. Check with some of your local roofers, one of them might have a piece left over from a job cheaper than buying a roll from a RV supplier.
Walt, your roof job looks great. I wish my little rig was as far along as your's, I now have to start on my interior.
Jeff & Micki
53 F100
Mercedes turbo diesel
Teardrop "finished" as if they ever are
You can never be lost if you don't care where you are going!
mechmagcn
Images: 56
Postby Walt M » Thu Aug 21, 2008 2:03 pm
Thanks Jeff, I started in June and was hoping to have it done by Sept. for a gathering in Ma. but I'll be diving in NC when the gathering takes place so I'll have to catch the one in OCT. it'll be the Noreastear's maiden camping trip. I can't wait to haul her out of the shop into the sunlight. working with all that steel your doing, must be a bit of work. Keep it up times flies before you know it. Walt
Walt M
Images: 50
Postby mechmagcn » Thu Aug 21, 2008 2:11 pm
Walt, I started my build in early May and hope to at least have it "campable" by late Oct. We plan to attend LCGIII and would feel sort of foolish if we pulled in with our Mack and 37' 5er :oops:
Jeff & Micki
53 F100
mechmagcn
Images: 56
Postby Walt M » Thu Aug 21, 2008 2:50 pm
To go from a 37' 5er to a tear drop is almost as bad as me. I've camped in a 44' Park model for the last 7 yrs. Can't wait to get on the road I'll be puttin some comfort features in when I decide on my final build. but the first one will be ready soon to start. Walt
Walt M
Images: 50
Postby Todah Tear » Thu Aug 21, 2008 10:06 pm
Thanks for your tips guys!
Todah
Todah Tear
Images: 282
Postby S.A.Mike » Fri Aug 22, 2008 3:58 pm
can epdm be installed directly over plywood that has been coated with west system epoxy resin if it is sanded ?
Thanks Mike
S.A.Mike
Postby Walt M » Fri Aug 22, 2008 4:13 pm
I don't think that would be a problem. you can use latex or solvent based bonding adhesive. neither will effect the epoxy. I like the latex product myself it takes a little longer to set up but, is easier to work with. You apply a nice even coat to each side( the substrate and the epdm) I like to recoat near the edge for a good seal. btw I rolld out a 15' peice from the front to the back right over the living hinge. then I folded it in half the long way, then I applied the bonding adhesive. Walt
Walt M
Images: 50
