Wikipedia defines an RV as “Recreational vehicle or RV is, in North America, the usual term for a motor vehicle equipped with living space and amenities found in a home.â€
2bits wrote:I am enjoying the suggestions that address the question since I am starting a TTT myself. We all have our own opinions, but can we please cut Peter a break and not run him off from the group? Lets just try to make our opinions constructive rather than dismissive. Remember this is the "Teardrops AND Tiny Travel Trailers" forum.
angib wrote:Here is some Volkswagen* wind tunnel data from a few decades ago:
So that's a reduction of 15% total drag by using the spoiler - huge. But this applies to this combination of European tow vehicle and relatively large, square trailer, so don't no-one go thinking all roof spoilers will give this benefit.
*Did you identify that car as a 1980s Passat by its profile?
Pottercounty wrote:Take a look at these.. we used them on some aircraft with very good results. They work the same with ground vehicles as well...
http://www.sigmaautomotive.com/performa ... ortekz.php
PhotoGuy wrote:An RV magazine did a bunch of studying on this topic. And the figured out the cost to buy the " wing" compared to the amount of money it would save you in fuel..... You would have to tow a lot for a number of years to pay for itself.
Pete S wrote:Pottercounty wrote:Take a look at these.. we used them on some aircraft with very good results. They work the same with ground vehicles as well...
I'll admit that I really haven't spent a lot of time learning about vortice generators. I've been curious but haven't taken it any further than that...
From my days flying my ski-plane all over hellandgone and flying out of most every grass strip I could find I remember guys putting those things on their wing leading edges. I think the idea was that by creating vortices they could make the airflow follow the top of the wing better (longer) at higher angles of attack. That would lower the stall speed by lowering the speed that stall burble happens. Steeper approach-to-landing and steeper initial climb promised they could fly out of shorter fields. How am I doing so far?
Ok, I am trying to see where these could be applied to our teardrops. The way I understand it at highway speeds air can't follow the shape of our teardrops. Instead it breaks away in what is essentially a stall burble. The slope of the top varies between the different types but at highway speeds where do you suppose the airflow separation is what can be done to make the airflow follow more roofline?
One of those "gotcha" things that I think might happen if you added these to the roofline on a sedan/tow vehicle is you would increase the speed and amount of airflow that you direct right into the front of the camper body. I'm thinking that would be counter-productive...
On the other hand if you mounted them on a deflector wing would they reduce the wake-burble? That could be REALLY useful! Right now what I think I have is a lot of air being launched nearly straight up at the front of the camper body. There is a strong enough vacuum over the top that the roof vent will open ALL THE WAY if the handle isn't tied off inside. If I could just get the flow over the camper to be reasonably flat...
So, assuming that I can get "reasonable" airflow over the top of the camper I'm curious what can be done over the back slope. I'm thinking that at highway speeds the airflow doesn't descend very far down the rear slope on a Ben-Roy type like ours. Are you thinking that by making it go another 6 inches or maybe an additional foot down the slope it would reduce the burble area and smooth some of the air in the stall-break area? Enough to make a difference?
I'm thinking a guy could get a piece of angle PVC (or maybe get box-section and cut it diagonally) and make their own VGs. The ones they are making for cars are pretty and all that but the ones I've seen on airplanes are simple flat blades. A little contact cement and let the testing begin!
Ok, who has a wind tunnel???
Users browsing this forum: Bing [Bot] and 6 guests
