I need a custom Awning?
Postby madjack » Sun Dec 12, 2010 9:22 am
Oasis Maker wrote:
starleen2 wrote:
Thanks to Doug H. who’s inspiration helped me to solve a droopy center . . .
And honestly, could there be anything worse than a droopy center? :roll:
...a droopy bottom :thinking: or even a droopy top :roll: ...................................... 8)
Postby Classic Finn » Sun Dec 12, 2010 9:24 am
Doug sure has a mighty fine design. ;)
Classic Finn
Midnight Sun Voyager
Images: 146
:lol: :lol:
Classic Finn
Images: 146
Postby Oasis Maker » Sun Dec 12, 2010 9:29 am
Yes he does, I'll take two. (Good to have a back up just in case.) :lol:
Oasis Maker
Images: 187
Postby doug hodder » Sun Dec 12, 2010 10:30 am
Classic Finn wrote:Do any of you have an idea as to how an awning can be installed to the Kit tear without the old style frame?
Finn....you can use this stud type system. These have a twist top on them, but on my '49 Kit it had a similar stud system to attach the hatch tent with. Each side of the Voyager has about 7 studs so that the awning can be attached to either side and I don't have that long track for the awning. Doug
Postby Classic Finn » Sun Dec 12, 2010 10:50 am
Doug thank you for the good info. How do I determine the size for it now? Also Id like to do one for our other tear.
This one. Its 5 foot wide.
Cant determine the width or length for it either. Course Im no sewer in any case. :lol: It does have the caravan awning aluminum profile on it as well. ;)
Maybe I,ll ask the wife to sew the awning welt onto an ol sheet and play with the shape and design a bit?
Classic Finn
Images: 146
Postby nevadatear » Sun Dec 12, 2010 11:38 am
Hikerjohnd wrote:
nevadatear wrote:Image
I'm planning an awning too. This style pole is just what I need! Where can I get something like that?
Thanks!
Hey Hikerjohd I got those poles at walmart. They are replacement tent poles. I got my adjustable tent poles for the outside also at walmart. Both were, if I remember correctly, @ $10 each. I used two packages of the replacement poles and one for the support. Instructions are on the replacement poles on how to cut to size. Just don't cut too short, you want to stretch it tight or it will still sag. Better to cut long then shorten if needed. If not available at the store, they are available on-line, that is where I got mine, with free shipping!
Whoops, I was wrong, they are presently 7.97 online walmart with free shipping until christmas. http://www.walmart.com/ip/Coleman-Replacement-Tent-Pole-Kit/13848639
nevadatear
Images: 171
Postby Hikerjohnd » Sun Dec 12, 2010 9:34 pm
nevadatear wrote:Whoops, I was wrong, they are presently 7.97 online walmart with free shipping until christmas. http://www.walmart.com/ip/Coleman-Replacement-Tent-Pole-Kit/13848639
WOOT!!
$6.88 in store!!!
Now at christmas I'm getting curtains and an awning!!!
Thank you all for the help!!
--John
So be it.
Hikerjohnd
Images: 88
Postby Dant » Fri Jun 17, 2011 11:59 am
I can sew canvas and have made several awning for my boat. I need ideas on how to deploy an awning for simple setup.
I want to be able to open the rear barn doors of my CT conversion and mount an awning simply to the rear top. I'm thinking of using flagpole type fasteners for the poles, fixed to the side walls near the floor, holding the poles straight out at an angle. Should only take two lines and stakes then.
But not sure how to do this with minimal fuss.
Dant
