Digital TV sucks
Re: Digital TV sucks
Postby bdosborn » Mon Jul 02, 2012 9:33 pm
I gave up on digital TV awhile ago as we couldn't ever get a signal out in the boonies. I came up with a solution that will make the TV haters apoplectic (yes, I watch TV but I still read 8) ). I recently copied all our DVDs to a new media home server. Then we got a WD TV live box with a USB hard drive that lives in the trailer. I converted the DVD format to an Apple format and copied them to the hard drive. Then I set up the Home Server to convert any new additions to our DVD library to an Apple format and copy them over the WIFI to the trailer. Our library is automatically updated with any new additions and now we take *all* our DVDs with us . The WD TV Live streams the movies to the DVD player in the trailer via a composite connection. The USB drive is also a WIFI hot spot that can stream up to 3 simultaneous movies via to the Ipad or our Iphones. We now have a DVD on demand library of several hundred DVDs and growing. We don't use digital TV anymore and life is good. Wanna watch a Thin Man movie anyone? How about a Thin Man marathon and we'll watch all of them? :lol: :lol:
Images: 806
Postby linuxmanxxx » Mon Jul 02, 2012 9:44 pm
I've been doing streaming at home about 3 yrs now. I even use rss feed and dload tv shows via torrent no commercials. Use patriot box office for my streaming player and it's hdmi and ultra portable. Use usb drive and flash drives to load content as well. Forget apple I use open source formats anything will play.
linuxmanxxx
Images: 10
Postby bdosborn » Mon Jul 02, 2012 9:58 pm
linuxmanxxx wrote:Forget apple I use open source formats anything will play.
I should say I use an Apple *compatible* format. I use Handbrake (free open source) to convert them from VOB to a M4V format. Then just about everything will play it, the file is a lot smaller and the resolution is pretty good.
Images: 806
Postby linuxmanxxx » Mon Jul 02, 2012 10:14 pm
So your ripping to an ipod/ipad compatible format thats different. Quicktime is apples format and rarely used. M4v is mp4 basically just the end renamed. Handbrake rocks I use it often.
linuxmanxxx
Images: 10
Postby 2bits » Mon Jul 02, 2012 10:30 pm
Sounds like a differentiation between format and encoding, but you both meant the same thing... Handbrake is my favorite for the task as well.
Thomas
2bits
2bit Member
Postby linuxmanxxx » Mon Jul 02, 2012 10:51 pm
I also run a subsonic mp3 steaming and download server which recently added video support. Can stream movies and tv shows to anything flash compatible so can watch then on my android phone anytime or anyplace.
linuxmanxxx
Images: 10
Postby GPW » Tue Jul 03, 2012 6:30 am
When I’m away from Home , all I want is the news (Weather mostly , certainly not the stupidity going on in DC ) .... Working on the idea of a PVC pole (telescoping) to support a small digital antenna ... Something easily attached to the side of the trailer ... Maybe I should just be Happy with a radio .... much less fuss.... and expense.... :roll: Smaller than a breadbox. :lol:
Postby Photoman33770 » Mon Jul 16, 2012 11:52 pm
That Nice homemade antenna in the pic with all the snow works fine. I built one about 4 years ago and put it on a antenna pole on my house. It works great and I would pick up about 8 more stations if I had a rotar and even more if I add a decent amp.
Digital is no different than analog in that they are both line of sight just like the radio. All that means is that the signal will not follow the curve of the earth nor pass through massive objects. That is why TV with an antenna in NYC is kinda bad.
The old analog TV did not care about signal strength, it just gave you what it had. As the signal got weaker the picture go fuzzy until you could not make it out anymore. Digital either has all the dig9ital info it needs or it does not. If the signal strength dies off to the point the data loses anything. Poof, no signal. Actually if you had a tester you would see the signal was there just missing packets of data and digital needs all them ones and zeros.
For me I am not worried about TV on the road because so much of it sucks I seldom watch it. I have cable and I watch maybe 4 channels. Science, history, FOOD, and any decent movie that any channel shows but they are few. I like sci-fi but most TV today is wrestling and reality shows and I hate both. I will however have my netbook, a TV as a monitor, and a hard drive with tons of movies. I am slowly ripping my DVD's to digital. When done with just what I have now it will be just over 2 TB of movies. But at least if I get rained in I can watch a movie I like or work on writing on one of my 2 books.
I would have the option of running up a small antenna in case I needed to check weather or something.
If you really want TV ( for the kids ) make one of those antennas and you will be fine. 8 coat hanger wires ( stripped of lacquer or rubber at the connecting points), a 3 foot board, 8 screws with washers. 2 soda straws and a barrel adapter. ( That barrel thing TVs came with in a plastic bag for years with 2 wire connectors on one end and a cable screw on connector on the other.) There are tons of sites out there with the exact measurements and directions for it all.
A pic of mine on a PVC pipe. ( not recommended as screwing into the curve and keeping the whiskers flat is a pain.
Photoman33770
Images: 9
Postby Richard A. » Tue Jul 17, 2012 5:43 pm
GPW wrote: .... Working on the idea of a PVC pole (telescoping) to support a small digital antenna ... Something easily attached to the side of the trailer ...
I use a painters pole. It works great. I support it with an old Radio Shack antenna tripod but you could mount wall pipe clamps/supports on the side of your trailer.
Richard A.
Boston, MA, USA
2008 Little Guy Silver Shadow
Richard A.
Postby PSBreen » Tue Jul 17, 2012 7:14 pm
Yep ! Digital TV sucks, but you have to ask yourself a question. Why are you going camping? Many of us go camping to escape all that electronic stuff. We enjoy being outdoors with the peace and quiet that you can't find in the city. But hey everyone is different. If you really need something to watch while camping DVD's are probably your best bet.
Steve & Cynthia
PSBreen
Images: 93
Postby beverlyt » Sat Jul 28, 2012 5:34 am
An update.
I went out and bought the antenna Richard A. recommended:
http://www.amazon.com/Winegard-FreeVisi ... tv+antenna
On our last camping trip I put the antenna on a retractable painter's pole. With a good antenna and getting the antenna up in the air, I was able to find 8 air channels in two different camping locations:)
Bev
beverlyt
Images: 20
