Idea for alternative 12v AC?
Re: Idea for alternative 12v AC?
Postby MtnDon » Thu Oct 23, 2014 1:33 pm
Dobromofo wrote:I am thinking this and a generator for boondocking in hot weather
http://www.globalindustrial.com/g/hvac/ ... onditioner
That unit is a 'one hose' portable A/C. The bad thing about them is they exhaust the hot waste air through the hose to the outside. That air needs to be replaced by having leaky construction or a window cracked. So hot ait enters.
The best portable units have 2 hoses, an intake and an exhaust. That prevents the introduction of hot air to the interior.
I have not tried one of these in a TD or small trailer myself. I have used a 2 hose portable in a small cabin (16x30) and it worked fine there. Many reports of unhappiness with the performance of a portable A/C can be found here on the tntt forum. That's why so many opt for the 5000 BTU window mount type.
MtnDon
Images: 24
Postby wincrasher » Thu Oct 23, 2014 4:11 pm
I used a similar type unit in my cricket. Bulky, noisy and you need to insulate the exhaust hose. Also need to collect the condensate.
2015 Little Guy T@G Max
Follow my blog: http://www.wincrasher.blogspot.com
wincrasher
Images: 88
Postby Kathy53 » Sat Oct 25, 2014 2:28 pm
What about this other than the price? http://www.turbokool.com/
Kathy53
Images: 60
Postby MtnDon » Sat Oct 25, 2014 3:41 pm
It will work with all the same "ifs, ands and buts" that apply to any method of cooling that depends on the evaporation of water. Only the packaging is different.
MtnDon
Images: 24
Postby GuitarPhotog » Sat Oct 25, 2014 5:49 pm
Kathy53 wrote:What about this other than the price? http://www.turbokool.com/
Any time you see the words "evaporative cooler" you have the same "swamp cooler" that works well only low humidity situations.
<Chas>
GuitarPhotog
Images: 55
