I want to make a camper I can dissasemble for storage
Re: I want to make a camper I can dissasemble for storage
Postby Roly Nelson » Wed Sep 07, 2016 10:58 pm
Wow, it looks like you have put a lot of thought into what you plan to build. I can relate to your off of the wall ideas. I have found that building a scale model, (one inch to the foot) out of cereal box cardboard, masking tape and glue, really helps. I had to make 8 models before I finally came up with the correct design for my stealth fighter camper. Keeping the rain water out of the trailer is one thing, but even more important is the effect of a hard rain when you are tooling down the interstate at 60 mph. Water will enter everywhere, if it is not properly weatherstripped or somehow protected from water intrusion. Been there, done that. Good luck on your proposed build, take pics of your progress and keep us posted. Keep asking questions, we love to hear them and respond. BTW, if you are interested in building a smaller rig, 40inches wide and 6 ft long, I have some plans I will share with you. I built such a unit that flips up on it's tail and stacks inside the garage against the wall, taking up very little room. It weighs only 245 lbs and works great. :-)
:D :? :thumbsup: Roly, of So Calif fame. (so to speak)
Roly Nelson
L'il Ol' Woody Builder
Postby OP827 » Thu Sep 22, 2016 8:36 pm
Check this out for inspiration!!! - https://youtu.be/dfr2aX9EgAU
OP827
Images: 414
Postby QueticoBill » Sun Nov 06, 2016 3:24 pm
Panels and coffin locks: http://www.rosebrand.com/product1674/Coffin-Lock.aspx Mortised into sides or simply bolted on, lots of alignment tolerance and pretty hefty load rating - which is probably about a third of the breaking strength - and quick to make or break - a quarter turn of a hex key (get a t- handled one). I'm not sure but once heard these were developed for the military for missile or warhead cases.
QB
QueticoBill
Images: 22
