Comparing weights of building methods.
Re: Comparing weights of building methods.
Postby GPW » Tue Nov 03, 2020 4:59 am
The first Foamie we can recall is one made by Glassice ~ 2005 (?) , and it was Fiberglass covered … And although his English wasn’t that great, he really got the message across how much a PIA putting fiberglass over foam really is ( finishing especially ) … And I don’t believe he ever got it finished … AFAIK, he just stopped posting … :o
And then the Original Idea of a Foamie ( as proposed here ) was NEVER intended to replace the well established TD building methods we all know and follow . It gave us a Thrifty and Light alternative to what was available at the time … Simply put , a “Hard Tent” … One that anyone could build at home with common tools , and materials … and not for a lot of money if sensible “salvage” principles were followed . ;) ( as explained in ” Thrifty Alternatives” , the thread that most have deemed too long to read … :lol: )
So Naturally Foamies are not for Everyone … But for some people they work just fine … :thumbsup:
IT’s ALL YOUR CHOICE the way you want to build your trailer , nobody is saying one way is better than the other , because that is subjective to the individual … Build what YOU want to … and what you need ! 8)
Postby GTS225 » Tue Nov 03, 2020 7:08 am
See.......Now this is the kind of response I was hoping for. Someone that had info about the weight of a poly tank. The style of tank he referenced wouldn't lend itself well to trailer it long distances, but the principal is still there. (The OP was, after all, talking about weight of building techniques.)
The vertical tank he referenced works well for what he used it for. Do the build, haul it where you want it for the season, and haul it back out. What we're looking for here is a permanently trailer mounted compartment that can be modified as a temporary shelter and sleeping quarters that is relatively light in weight. A horizontally configured agricultural tank of appropriate size is rot-proof, not quite indestructible, and depending on material, can be modified to fill the requirements quite nicely.
As I alluded to in my second paragraph in my previous post, yes the original running gear is far too heavy and tall for our needs. I shouldn't have had to specifically point that out to anyone, right along with the need to cleanse a used one of whatever had been in it previously, but apparently my assumptions were incorrect.
Dogcatcher, thank for referencing what you did for your build. It supports my thought processes. Now the only thing holding me back is the expense of one of those horizontal tanks. (I should have stuck around a farm auction two years ago, dangit.)
Roger
dogcatcher wrote:Today I can get a brand new 1500 gallon poly water tank for $750, weighs 210 pounds. It is close to 8 foot in diameter and 64 inches high. Cut a door, 2 window openings and enclose them for $250. I know, I have a 5 year old deer blind that is made like that. 2 of us loaded on a trailer along with camping gear and the first night at deer camp it rained, so we opted to sleep in the water tank/deer blind. Dry, warm and comfortable. It has also been through several West Texas hail storms, without a dent, not to mention 5 years of sun, cold, and all kinds of weather.
Granted, it is not a tear drop, and it does NOT LOOK LIKE travel trailer, but it would work, looks "cool" and you could be the talk of the camp grounds. 200 cubic foot, about the same as an 6x8x4 trailer.
https://www.plastic-mart.com/product/11 ... 9UQAvD_BwE
GTS225
Postby RJ Howell » Tue Nov 03, 2020 7:10 am
saltydawg wrote:Would you try to make a 12 foot long body with 5.5 inside width and almost 5.5 inside height out of foam and pmf?
What I meant is I dont think it could handle larger size trailers ie over 10 to 12 feet long 6 feet high and wide, twisting and turning down really rutted roads.
Yes, I would with foam and fiberglass, but I do have some engineering/building skills. I have yet another design to work through and actually my first and why I joined here to begin with. Everything I have built has been a learning process to build this! Design will change, but size is totally doable!
RJ Howell
Images: 36
Postby aggie79 » Tue Nov 03, 2020 8:27 am
There are many methods/approaches to teardrop and TTT construction. All have merit. As with anything in life, the project build must balance expense, construction time, shop size, tool availability, builder skills, design functionality, design aesthetic, etc.
Although I used somewhat "conventional construction" (insulated floor, insulated plywood skeleton walls, insulated roof, aluminum exterior), I have always admired the lightweight design and aesthetics of Alaska Teardrop's Northern Lite Traveler: http://www.tnttt.com/viewtopic.php?f=27&t=51991. He used readily available materials. His construction techniques appear to be repeatable by persons with average construction skills. The design can built in a single-car garage with generally basic and/or low-cost tools. The end result is a lightweight, attractive teardrop that is able to be comfortable in and stand up to weather extremes.
Postby saltydawg » Tue Nov 03, 2020 8:43 am
RJ I like to look of that build, what are your over all dimensions? Also yes I think that would be do able with fiberglass over foam, esp if you put in some minor framing around things like doors and windows to stiffen it up there.
You should look up the lifestyle reconn r2, very similar over all shape.
Scott
Lost in Maryland
saltydawg
Postby RJ Howell » Tue Nov 03, 2020 9:53 am
saltydawg wrote:RJ I like to look of that build, what are your over all dimensions? Also yes I think that would be do able with fiberglass over foam, esp if you put in some minor framing around things like doors and windows to stiffen it up there.
Works out to 12''-6" long (including rear storage) by 7'-4" wide. I have learned so much from my builds and experimenting that I now see how it can be done. Only wood would be blocking for solid attachments. I see now that the windows (as draw) are not required, as with my truck camper lift roof the material is at chest/eye level and gives a great viewing of outside. I see much of the structural components this time being of fiberglass (possible gel-coat). I have a bit more testing to do before starting into this.
The truck (Overlander) build worked out so good, I'm currently searching for a 2010-12 F350 SD Extended cab to build a true walk through Overlander. The trailer would be to tow behind for a base-camp unit. We love both ways of camping and in each build I love the Foam-built (even if hybrid, as most are) for how light and durable they are.
We each have our ways of doing things.
RJ Howell
Images: 36
Postby Ottsville » Tue Nov 03, 2020 10:11 am
One thought about a tank, those things would be like a sauna in sunny conditions.
Ottsville
Postby Newb1 » Tue Nov 03, 2020 1:08 pm
Thanks to all that have led me to find more about my original question and the feedback from others.
I cant reply back to everyone individually but I do want to address (GTS225's idea)
"As a bit of a sidebar to this subject, I've wondered a few times how something like this might turn out in the weight department.
https://www.equipmentfacts.com/listings ... 1586475144
This one happens to be 1000 gallons, but I've seen a 1600 up close, and it seems to me that it would lend itself quite well to a somewhat roomy camper shell. One would surely not need the running gear or pump systems, as it would never be carrying the weight of the fluid again."
Thanks to all again for all the help,advise, and other articles and videos links you've sent.
Newb1
Postby dogcatcher » Tue Nov 03, 2020 1:22 pm
Roger
The horizonal tanks would be better for travel purposes. Split the tank into a Quonset hut look with a flat floor. I see huge steel oil battery tanks turned in to farm shops in the oilfield. The top half of the tank is left in tack, the bottom split and then bent straight so that it looks like an upside down U. Redo both ends of the tank with door and windows then add a floor. This raises the roof a little and allows a solid one piece roof.
dogcatcher
Postby GTS225 » Tue Nov 03, 2020 1:53 pm
Newb1 wrote:Thanks to all that have led me to find more about my original question and the feedback from others.
I was REALLY confused at 1st reading this and Ive seen a lot of feed back about it. I THINK maybe he was saying, you could make a mold like these tanks are made, then you'd have a polyethylene tank in the shape of your camper, etc etc etc...
Then again, I could be 100% wrong.
Actually, I was suggesting using one of those tanks, and modifying the design to incorporate a door and windows as desired. Could a person go the route you suggested? Sure, but it would be expensive for a one-off build. It might lend itself well for a production teardrop out of a weatherproof material to start with, but one would still have to build in some internal walls, insulation, door(s) and window(s) as desired.
Would one of those tanks be a teardrop?.....No. However, this board also accepts less-than-teardrop shaped small campers as well, and your initial query was concerning weight of builds, not shapes or materials.
Just offering up an idea from the dark recesses of my shoulder-mounted vacuum chamber.....Roger
GTS225
Postby Newb1 » Tue Nov 03, 2020 4:02 pm
RE; Actually, I was suggesting using one of those tanks, and modifying the design to incorporate a door and windows as desired.
OK, im 100% wrong then. Thanks for the thought anyway. :beer:
Newb1
