I installed a roof rack and rack basket on the TrailTop to do some more weight testing. This first photo shows the basic roof rack bolted to the top of the shell. When I built the shell, I added blind nuts to two of the roof cross-ribs for this rack, so the rack screws in from the top.
I use this basic rack for carrying things like plywood on my military trailer, it's got extension bars for that purpose, and it's also designed to be a base for a rack basket and a roof-top tent. The next photo shows the rack basket attached to the base rack, and loaded with a spare tire and a Hi-Lift style jack.
And in this next photo, it's loaded with all of the above, plus the 225-lb. gorilla.
The total weight on top of the shell is somewhere between 325 and 350 pounds, which is more than twice what the TrailTop shell weighs - the shell is only about 150 lbs. The gorilla also did some bouncing up and down while up there to simulate the trailer going over bumps with a load on the roof; no problem.
The shell supports this weight very nicely - there's no flexing, creaking or movement of the shell when I climb up there with all this weight. Considering that the only structure in the shell besides the TrailTop fiberglass framing parts and the 1/4" plywood skin are the three 2x2 cross-ribs in the roof, and considering this prototype is only bolted together at the moment, I'm very pleased with how the strength of the TrailTop assembly has worked out.
Next... the rack basket comes off and the roof-top tent gets installed. Photos later.
