Know your equipment - true story
Re: Know your equipment - true story
Postby Dale M. » Thu May 23, 2013 9:57 am
Jim Edgerly wrote:
warnmar10 wrote:
Dale M. wrote:
alaska teardrop wrote:
Though Jim has put me on his FOE list (but that is his loss)....
The tire temperature method (side/middle/side) is what we use to measure proper inflation pressure on our race car tires.... Also works on street tires... As little as 1/2 psi will change how tire heat is distributed... On the autocross course we always adjust tire pressures between laps, but for us its all about tire patch and traction....
Dale
Something I've had success with; raise the tires off the ground, liberally paint the tread with tire black and let dry. Once dry, lower the jack and gently drive to full speed and hold for a mile or so. Stop the car, get out and take a look at what is still black and what isn't. On short/wide tires it's very effective.
I thought I had successfully erased dale from my life by putting him on my Foe List...but alas he keeps on repeating like too many beans ingested too fast. How vain/conceited does one have to be to think that my life is lacking because I have removed him from it. HAhahahaha I was enjoying seeing that he had posted insults towards me because I disagreed with him, without actually having to read that insult, and him knowing he was flogging someone who could not defend them self against his garbage.
He just doesn't get it. I don't value his opinion, just like he is trying to liken my teardrop to a race car that needs my tire pressure adjusted every 2-3 miles dependent on 3 temperature readings taken on both tires every 3 minutes. I mean seriously how many teardrop owners in here are using a pyrometer every few miles to check their tires to see if they should increase or decrease their psi by "1/2 pound?"
Some people like to carry things to the extreme. READ MY LIPS...I am running 50psi according to what the experts recommend regardless of your opinion. Please, please, please add me to your Foe List and stop the harassment.
But perhaps others do value what I have to say..... I'm here to help any who want it and to learn, not to bedevil you. You are a party of one in your opinion and that's your choice.... Now its time for you to let it be and if what I say offends you just ignore it and walk away.... Others don't seem to mind, at least I have not been blocked by Admin or been told to go away by other users.... It's your problem, not the boards.... But I will not block you, by chance there will be a moment when realization sets in that information you steadfastly maintain is correct is finally realized as wrong.... But you will probably never admit it...
And my reference to tire inflation of a race car is not in any way directed at you or your tire inflation concepts... That is your ASSUMPTION, it was my intention to reinforce other opinions that tire wear is directly related to tire pressure.... You have to high a opinion of your self and you seem to think ever thing is about you.... Well its not... You are not that important to me at all.... Get over it!...
And I don't think other are buying in to your concept that I am here specifically to harass you....
Admin it's either time to lock this thread or to tell the gentleman to stand down...
Dale
Dale M.
Images: 18
Chalk Test results are in
Postby Jim Edgerly » Thu May 23, 2013 1:49 pm
Chalk test results are in. I bought some sidewalk chalk (for 64 cents...such a bargain) to make a nice wide white/yellow chalk mark across both tires, between an inch and 1.5 inches wide. Drove down the street about 100 yards and got out and checked both tires. The chalk is worn off evenly from outside to inside on both tires. I took out the tire gauge and the left tire shows 49psi, and the right tire shows 50psi. It is conclusive without a doubt that my tires are properly inflated at 50psi. I'm going to leave the left tire at 49psi until both tires need re-inflating, then bring them both back up to 50psi. As far as I am concerned the hard evidence conclusively proves my tires should be at 50psi. THIS CASE IS CLOSED AS FAR AS I AM CONCERNED! Wish I had done this test earlier.
*When doing anything, if there exists no possibility of failure, then any feeling of success is diminished.
**The glass is neither half full nor half empty...it is simply twice as big as it needs to be.
***If at first you don't succeed, redefine success.
****When I die, I want to die like my grandfather, who died peacefully in his sleep. Not screaming like all the passengers in his car.
Jim Edgerly
Images: 142
Postby PaulC » Thu May 23, 2013 4:44 pm
Sorry, this thread is now locked
PaulC
3rd Teardrop Club
Images: 36
