alaska teardrop wrote:From what you're saying, it seems to me that by distinguishing between wood & foam board structure (what holds it up & together) you've created a chart that is a three part equation. The size & type of structure helping to reference the weight.[/list]As to tradition, small travel trailers have long been built, and still are, using metal structure: Modernistic, Tourette, Airstream, Five Wide Club, Dandan (Roswell), MeelisV. Current builders: EMiller, SST1100, Dean-Petley and most cargo trailers for example. Refering to any of these trailers as being built with plywood just isn't right.
And let's not forget molded fiberglass & plastic trailers.
How about typing in a question mark if you don't know? Someone like Gage is bound to fill you in.
You have a good chart started & I appreciate that you've taken on this on-going project. Thank you, Sharon.
Fred
p.s. edited first post with added pictures per request.
Jdw2717 wrote:If you have not shown it yet it may be nice to have the high and low weights added below the average weight so people have the two extremes to compare. That way they could see how light they could be built or how heavy. Just a thought. Thanks for the hard work. I like to see where I "stack" up.
S. Heisley wrote:KCStudly wrote:planovet wrote:Plywood, Trailer is 5x10 but total length of teardrop is 5x11, 2400#
I think Planovet should get an honorable mention for having such a sturdy trailer frame. Surely that is contributing to the relatively high overall weight.
One of the classics.
You're right, KC. Also, he built his cabinets out of beautiful Oak, which is a heavier; but also, sturdier wood. Planovet put a lot of thought, sweat, and maybe an occasional sawdust tear and a little blood into his trailer and got exactly what he wanted. If he is happy and it works for him, what does it matter if it weighs 1400 or 2400 lbs? The only way that it matters is that someone else can look at the way he built his and decide whether the weight will a problem for them when they build theirs, if they choose similar materials and building processes. As stated previously, there are builders who build heavy and those who build light; and, people will be able to see that, as well as the averages.I may need to do a median weight, too...we'll see....
working on it wrote:Sharon- I wish you had asked for the tongue weights (if known) as well...I would be very interested in seeing the range of what tongue to total weights works, as compared to the "ideal" range we all tried to achieve.
