Testing Spent the night in the camper with my dog. -11f windchill -26.
Had the regulator set on low.
ki
The heater worked good. It was very comfortable(A Unzipped sleeping bed and in my underwear). Used the windows to control the temperature. The down side the radiant heat is like a tanning bed or sitting be a window in the sun. I had to pull a sheet over my head.
Looks like the heater works almost too good in that I had it on low. I should have weight the tank to see how much propane I burned. Maybe next time.
There as a little heat build up behind the reflector. I think using just aluminum foil on a wire frame would solve that.
Would I recommend this type on heater. Yes
Any questions ?
Disclaimer
Like anything One builds, be careful and test it safely before using. I am not a expert and I have not tested for all conditions.
