Small Heater Question
Re: Small Heater Question
Postby backstrap bandit » Wed Dec 17, 2014 10:18 am
That's where the fantastic fan with reverse comes into play and thanks for the concern
backstrap bandit
Images: 15
Postby Vedette » Wed Dec 17, 2014 12:19 pm
We won a 12V Mattress heating pad at the IRG. Have only used it one weekend....but it works great! :thumbsup:
Plug it in 5 minutes before we go to bed while we go to brush our teeth.
By time we get settled in bed and say our Good Nights, the bed is warm and toasty.
We shut it off at that point and good for the rest of the night.
Good Roads
Brian & Sandi
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Postby Plainsgirl » Wed Dec 17, 2014 4:14 pm
That Hampshire heater is stunning Pretty eccy-pensive, but. Could one be made by a clever metalworker, I wonder, out of recycled stainless somethin-arruthers? After all, it it just a tiny combustion heater. I love how that one is vented. Ventilation, ventilation ventilation. Breathing ANYTHING but clean air freaks me out and defeats the purpose of going bush.
Plainsgirl
Postby rowerwet » Wed Dec 17, 2014 7:26 pm
I was wondering that myself, I'm not even sure stainless is required, just good tight joints.
I am trying to find out how it is set up on the inside.
rowerwet
Images: 521
Postby MtnDon » Wed Dec 17, 2014 7:59 pm
S/S probably is not needed, but since it is intended for a marine environment it is no surprise they use S/S. But if it was not S/S what will prevent surface rust from forming throughout a humid warm/hot summer? Not sure stove black as used on cast iron stoves would work on mild steel.
MtnDon
Images: 24
Postby Rainier70 » Wed Dec 17, 2014 10:48 pm
High temperature stove paint would keep it from rusting. They have more colors than just black anymore, but I still prefer black.
Rainier70
Images: 244
Postby kirkman » Sun Dec 28, 2014 8:50 am
Here's one some one made. It does need some refining for temp regulation but it would work. Any one with any welding skill could really make this design into a really nice stove even ad a shroud like the marine one.
http://www.bluemoment.com/simplestove.html
kirkman
Images: 55
Postby GuitarPhotog » Sun Dec 28, 2014 12:50 pm
kirkman wrote:Here's one some one made. It does need some refining for temp regulation but it would work. Any one with any welding skill could really make this design into a really nice stove even ad a shroud like the marine one.
Looks good, except for the fact that it uses room air for combustion, a no-no in a small space like a teardrop trailer.
Safety first
<Chas>
:beer:
GuitarPhotog
Images: 55
Postby kirkman » Sun Dec 28, 2014 3:40 pm
That's why you leave a window open a crack like with all heat sources that don't use a outside air intake.
kirkman
Images: 55
Postby Tucguy » Tue Dec 30, 2014 2:50 pm
I would not use any of these stoves and or propane heaters if they did not use a separate duct from the outside for outside air to be used for combustion. Not in a tent either. There are plenty of stories of people dying in tents from carbon monoxide poisoning. There are a couple of those boat heaters that use propane and also have an outside source of air for combustion. The price is the BIG problem there. They are beautiful and will do a fine job but cost as much as some of our tears. I would love to have one that uses charcoal and is plumbed to use outside air. It would be the ticket. I do like Kenneth's radiant tube heater. I would like to be able to control the heat from inside if possible. His design has definite possibilities. I own a Little Guy and would like to do one if I can figure out how to control the regulator from inside.
Tucguy
Images: 53
Postby bobhenry » Tue Dec 30, 2014 2:56 pm
Just turn down the damper !
:laughter:
Postby kirkman » Fri Jan 02, 2015 2:47 pm
Bob....As always, you have the coolest stuff! :thumbsup: :beer:
kirkman
Images: 55
Postby Plainsgirl » Fri Jan 02, 2015 7:55 pm
Check this out. This is the duck's guts! (That's Australian for 'the coolest of the cool')
http://www.duckworksmagazine.com/12/howto/woodstove/
Plainsgirl
Postby KennethW » Fri Jan 02, 2015 8:34 pm
Petty cool. On the heavy side. If it had a outside air intake it would be a winner in my book.
KennethW
Images: 82
Postby Plainsgirl » Fri Jan 02, 2015 11:59 pm
Kenneth I agree about the intake from outside, and that would be way easy to do, too. This is one a teardropper on FB is making: https://www.facebook.com/photo.php?fbid ... =1&theater
But the weight, I think would be fine because it's finished size is 6 x 6 x 8. Two solid house-bricks? Where to position it..now THAT is the question...
I can so see this little heater with a few laser-cut decorative stainless embellishments..girly, like.
Plainsgirl
