a nice little country copper's outpost, so they'll very likely be civilised about it.
Anytime I'm in a little town and wondering about a good place to eat, I flag a cop down. They'll tell you the straight skinny.
...a Patrolman came up to the truck...
Here in Oz there are no small local departments. Each state has a police force and there is a federal one but the state forces are the primary that most people will encounter. That's it. County coppers work for the state force and all trained in the main academy.tony.latham wrote:...a Patrolman came up to the truck...
Six-bits says that the guy worked for an awful small department. (Which is probably poorly trained. I'm cringing with that image.)
edgeau wrote:Here in Oz there are no small local departments. Each state has a police force and there is a federal one but the state forces are the primary that most people will encounter. That's it. County coppers work for the state force and all trained in the main academy.tony.latham wrote:...a Patrolman came up to the truck...
Sent from my Pixel 3 using Tapatalk
I Only Know two bit's
edgeau wrote:We decided to get the 'drop out one more time before our summer holidays end. The youngest goes back to school and I go back to work on Monday. Absolutely poured down all afternoon yesterday while we set up but cloudless today.
Tom&Shelly wrote:Today I shoveled snow! By lunch time I only had about 2/3rds of the driveway done, but it's so much fun, I figured I should save the rest to enjoy tomorrow. We're retired, so we aren't going anywhere, and the county plow hasn't made it to our road yet anyway.
This afternoon, I finished making some straight edge guides for my router and 1/2 inch trim bit![]()
Identical principle to the homemade track saw guides for a circular saw. It's important to use the centering cone before trimming the edge to size.
I already made 4 foot and 5 foot guides for the teardrop build, and was using them for smaller pieces, but the clamping gets tricky, and if not done right, I found the pieces slide under the guide, so I made a bunch out of scrap wood in 3 inch increments. I don't have a jointer, so for 4 and 5 foot guides I used the router in the table with a split fence and shim. These I made based on the 4 foot guide.
To trim plywood, I've been in the habit of cutting close to the line with a jig saw and then using the guide and router to straighten the edge. Our table saw isn't really that good, so I try to find other ways of doing things. Right now, the circular saw that's in the shop (which is probably the obviously way to do it) has a stud cutting blade on it. If we ever get our other circular saw back from a relative, I'll probably put a plywood blade on that one and make another set of these for that combination.
Now, I need to make a rack for these...![]()
