Revised list 131 trailers' size & weight pg 1 - graph pg 8
Re: Please post your completed trailer's size/weight
Postby Colemancooler » Wed Aug 28, 2013 12:12 am
5'x10' 14' long with tongue 1340lbs
Colemancooler
Postby Roo Dog » Wed Aug 28, 2013 2:47 am
Peewee is 8x5 and 880lbs.
RD
100_1751 (500x333).jpg (222.18 KiB) Viewed 1653 times
Lets do a three sixty and get out of here !
Roo Dog
Postby S. Heisley » Thu Aug 29, 2013 9:07 pm
Thanks, all. I've been doing small camp trips and checking in, now and again. I'll update the spreadsheet this weekend.
Postby S. Heisley » Mon Sep 02, 2013 12:35 am
Revised Chart is on page 1. Thanks.
Postby working on it » Mon Sep 02, 2013 12:53 am
Sharon-That's a lot of work you've done; I hesitate to point out one omission: in the statistical summary portion, you didn't add in my 1438 lbs in the 4x8 category. Maybe intentional, because mine is so far off the norm that it skews (screws?) the averages? Anyway, good work, again!
173193172890148599
working on it
Images: 457
Postby S. Heisley » Mon Sep 02, 2013 12:58 am
Gee, working on it, it should have automatically been recalculated. Hmmm.... :thinking: Not a problem. I can ask the Excel program to recalculate and then I'll reprint that page. Give me a few minutes and I'll recreate that page. I didn't even check because it's supposed to be automatically done. Thanks for catching that so quickly! :)
Postby S. Heisley » Mon Sep 02, 2013 1:11 am
Thanks to all who have contributed! To date, we have 108 trailers listed.
Below is what I am calling the "Updated Final Draft". :lol: I know that these are not the best photos (my scanner needs to be "retired".)
However, if you see something that needs correcting please let me know and I will try to accommodate any necessary changes.
March 14, 2014, Please note: Spreadsheets have been updated and moved to page 1.
Re: A List of 108 trailers' size & weight
Postby citylights » Sat Jan 04, 2014 9:24 pm
Sweet! Thanks for the summaries.
"The cooler" 10x5 with 3/4 plywood sidewalls and deck, full roof rack, tongue box, aluminum skin, air conditioner, battery, stove, full galley.... 1750 lb.
citylights
Postby Colemancooler » Sun Jan 05, 2014 11:10 pm
this is a great bit of information. i believe that the colemancooler 5'x10" is listed as 880lbs ( squinting) it is actually 1,340lbs. thank you for all the work :thumbsup:
Colemancooler
Postby webbaldo » Mon Jan 06, 2014 10:02 am
8x4 Plywood/Alu construction weighs in at 320kg unladen.
Cupboards inside and full galley
Likes to think he's Norm from New Yankee Workshop
In reality, hes a average DIY'er with a 18x16ft Wooden shed
webbaldo
Postby S. Heisley » Mon Jan 06, 2014 8:12 pm
Oh, boy! It looks like I'm going to have to update this list again! I'll wait a while and see if anybody else chimes in with more information, though....
Thanks to all of you. Giving your information helps others. :thumbsup:
Postby tony.latham » Tue Jan 07, 2014 10:56 pm
5x10, with 4' tongue, and sandwiched walls. 1380 pounds with the battery. It's the one in my signature line.
Postby eggsalad » Sat Jan 11, 2014 5:06 pm
The Coffin weighed in today.
I know it's not the most accurate method, but one tire on the scale came in at 205. The other tire came in at 195. Tongue down, that weighed 70lbs. (I leveled it for an accurate tongue weight, that's 65 lbs.)
By my math, the total weight is around 470lbs. Since the method isn't entirely perfect, I'll figure for a + or - of 10%. So the whole thing weighs between 423-517 lbs. Since my design goal was 500 lbs., I'll call it a winner!
-eggsalad
eggsalad
Postby working on it » Sun Jan 12, 2014 2:29 pm
Sharon, I hate to do this, but here's the latest data on my ever-morphing trailer build, as long as you're updating your table:
    Total trailer weight 1515 lbs
    *LCG from rear - 55.5 inches
    Weight on axle 1345 lbs (88.8% of total wt.)
    Weight on each wheel 672 lbs
    Weight on hitch 170 lbs (11.2% of total wt.)
    *FURTHER NOTE: from another spreadsheet, calculated vertical center of gravity is 28.7 inches
Additional info:
    Body length from rear - 98.0625 inches
    Hitch center from rear - 140.6875 inches
    Wheel center from rear - 44.75 inches
FYI, TMI, LSMFT (whoops!, got carried away there....)
173193172890148599
working on it
Images: 457
Postby S. Heisley » Sun Jan 12, 2014 8:01 pm
Thanks for all the new information. I'll see what I can do to update our size and weight charts. :)
